Old 06-09-2022, 08:46 PM
Bavafa Bavafa is offline
Originally Posted by rongawer View Post
Here's my new S10 housing with an oil vent (the reusable version of poking a nail in the filter). Beautiful craftsmanship.
I think I will need this to be explained to me. What is the intent for this hole?
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - Out of Paint shop & flying
Dues paid
Old 06-10-2022, 08:32 AM
rongawer rongawer is offline
The main intent of it is to minimize oil mess during changes. It does this by providing a vent port, or vacuum breaker, if installed with the port facing upward, or a drain port with the port facing down. If installed horizontally, it still provides a vent port, but may or may not be worth it to you. In all cases, it allows you to drain the oil from the filter in a controlled manner.
I experience essentially no oil dripped on the engine at change.
The port threads are 7/16-20 and work with an AN814-4 plug which has an o-ring.
Click image for larger version
Ron Gawer
- RV10, N762G, Build in progress.
- Several others that are now just great memories for me.
Old 06-10-2022, 09:12 AM
Nice mod and thanks for explaining. Are you planning on putting a safety wire on the plug?
This looks like it was machined to accommodate for the o-ring.
Mehrdad
Dues paid
Old 06-10-2022, 03:58 PM
I do safety wire the plug through the filter housing to the filter base, same piece of wire...easy.
I do it out of habit, although I've never actually had an oil filter come loose on anything I've installed one on, including an enduro bike which gets much more vibration and pounding than any airplane ever will...but that's a topic for the "to safety wire, or not to safety wire your oil filter" debate list and probably not what you're asking.
The plug opening is in fact machined for an o-ring. It was milled to the dimensional standard for an AN814-4 plug, but not anything I take credit for - I bought it from K&P Engineering that way. (usaoilfilters.com)
Ron Gawer
Old 07-08-2022, 03:19 PM
Utah-Jay Utah-Jay is offline
Originally Posted by gasman View Post
Thanks.... You just saved me $30.00 and free shipping.....
I see the ECU ships with the nipple, which I don’t need? I am using an Airwolf remote setup what has the male threaded for the filter to screw on already
Bearhawk Companion QB Builder
Revo Sunglasses Ambassador
https://www.instagram.com/jay_townsend_utah/
https://www.youtube.com/channel/UCQ0...tBJLdV8HB_jSIA
Old 07-08-2022, 04:36 PM
GaryK's Avatar
GaryK GaryK is offline
Ron,
Do you have the part number for the O-Ring used on the AN814-4 Plug. I like the idea of draining the oil in a controlled fashion.
Gary
Old 07-10-2022, 01:12 PM
Originally Posted by GaryK View Post
Ron,
Gary
The o-ring is 3/8" ID and 1/16" width. MS28775-012 is the right PN.
The controlled drain is definitely nice; little to none oil drips.
Ron Gawer
Old 07-10-2022, 04:55 PM
Flyyak Flyyak is offline
Default S15 and McMasters Carr nipple
So I understand that S15 and a 3/4 16 nipple will be the unit for a lycoming 0360. Will one of these McMaster Carr nipples work and if so what is better or does it matter?
ID:	28006  Click image for larger version
Flyyak
RV 7 with 350
I0360
G3X touch & G5
Old 07-10-2022, 05:11 PM
dpansier's Avatar
dpansier dpansier is offline
The two examples shown will not work as they are NPT threads, the filter requires a 3/4-16 straight thread nipple.
Don Pansier
Green Bay, WI (GRB)
RV-7
Antennas for Experimental Aircraft
www.deltapopaviation.com
Old 07-11-2022, 03:21 AM
rv8ch's Avatar
rv8ch rv8ch is online now
You can buy one here, or cut one out of an existing oil filter.
https://www.pegasusautoracing.com/pr...p?Product=1234
Mickey Coggins
http://www.rv8.ch/help-people-in-ukraine/
