Old 03-01-2010, 02:10 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
I'm still lost on the benefits. If the complete rudder control mechanism was hidden from view, then I see the advantage. But once you add exterior rudder cables and the rudder horn to the equation, then hows a piece of triangular aluminum for the stop going to make much difference in looks. It's that cable & linkage that isn't pretty!
L.Adamson --- RV6A
Old 03-01-2010, 02:48 PM
pierre smith's Avatar
Default Mark, mine was too thick.....
Originally Posted by Maxrate View Post
Pierre,
What did you use to shim the block to get the perfect fit.
PS: I flew with a guy the other day who was a turbine Air Tractor driver. Looks like a real Cadillac.........
....since the blank piece came from Spruce and after I cut it out on my bandsaw, I had to spend quite a bit of time on my belt sander to thin it down to fit.
Yep, the 'Tractor is pretty much the ag airplane of choice but the Thrush drivers won't change airplanes for anything.
Best,
Rv10 Sold
46 years ag pilot/CFI
Air Tractor 502/PT-6
Building RV-12, Wings, fuse, emp complete. FWF in progress.
Old 03-01-2010, 03:03 PM
Maxrate Maxrate is online now
Pierre,
I see. You actually fabricated your own. The one I purchased from Craig is too thin and will need a shim. As a Tech guy is there any recomendations on what you would use. Are AN washers OK?
The most amazing thing to me about Ag ops is how far GPS technology has advanced operations. He was able to operate into the night with no flagmen.......Amazing.
Thanks for the input.
Mark Malone, RV7
Wings complete, SB 14 complied with, canopy and cowling in progress, Up on the gear.
N442MM reserved
http://www.mykitlog.com/MikeMike
2021 Donation gladly paid..
Old 03-01-2010, 03:33 PM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
On the other hand....have you ever seriously reviewed the stress issues?
Dan,
When do we expect these stops to come under stress? Only 2 conditions I can imagine are at full deflection either by pilot input or in the case of an unrestricted/unrestrained rudder being blown by the wind. Of these 2 which one are we most concerned with? I believe I have read of rudders being bent by the wind when a rudder gust lock was employed.
Dave
I should hopefully see very infrequent full rudder deflection, as was demonstrated to me in my transition training in Vernonia, since brakes are used so often in ground steering, and full deflection on short final indicates the landing is likely beyond my capability this early on. Later, who knows.
I am one of those who query this "modification" for stress reasons.
In answer to
I am not really concerned with either. They will not kill you, and most likely, if any damage were to result, visible on a walkround check, and just cost ??? (or $$$!) / time.
My concern is a 3rd condition - a (presumably) inadvertant tailslide. This, to me, is the ultimate "stress" for a Rudder Stop (and Elevator). It takes a scr*wed up aerobatic manouevure, and a mishandled recovery... however, I have seen both together, both by me and more frequently, students... If you have not done a tailslide, please let me assure you the control forces as they reverse are harsh, and if you fail to hold them, a real hard/fast application of full rudder / elevator
The problem in the RV case is that if the "modified" rudder stop fails (in fact, I doubt it will be the stop that fails, it will be the rudder) what now stops it? Well, the elevator, and rudder jammed into elevator only equals one outcome
So to me it is a risk benefit analysis. The "benefit" is a slightly more sexy looking rudder stop. The risk? Death to both occupants probably.
So to
but I've never heard of any actual problems or data to support their findings
I am glad you have heard of no problems... just when/if we do, they are likely to be major. As for data - surely it is not us that have to provide the data? Van's provides the design, presumably to an accepted protocol / design standard. It is surely up to those who choose to override this should provide the data to "prove" their alternative is equally, or more, safe than the Van's design?
Please do not get me wrong. Anybody who chooses to modify their design at their risk I am fine with - we all take risk/benefit decisions every day. My concern is with those who encourage others, without expressing all the facts, to modify the Van's design, and even make $$ out of it. Go back to the original RV-3 design issues and fatalities, and the RV-8 prototype accident... In my interpretation, Van's design in both cases was proved correct, but not far off optimal
Andy
RV-8 G-HILZ
Old 03-01-2010, 03:57 PM
Flying Scotsman Flying Scotsman is offline
Is this event within the designed flight envelope in the first place?
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 01-19-2022, 11:07 AM
sblack sblack is offline
Anyone have the cad file for the internal stop? The only link I could find is dead.
Scott Black
VAF dues 2021
Instagram @sblack2154
Old 01-19-2022, 06:25 PM
BlakeFrazier's Avatar
BlakeFrazier BlakeFrazier is offline
Default Product link
Hi Scott,
Looks like a pretty old thread you've dug up, which is probably why the links are broken. We carry the product discussed here on our website here: https://flyboyaccessories.com/produc...al-rudder-stop
_____________________________
Blake Frazier
Co-owner of Flyboy Accessories
VAF Advertiser
2022 Dues Paid 1/19/22
Old 01-19-2022, 06:28 PM
Originally Posted by BlakeFrazier View Post
Hi Scott,
Yes Iíve seen it. It looks great. I have a cnc machine so I wanted to cut my own.
Scott Black
VAF dues 2021
Old 01-19-2022, 08:37 PM
Scott Hersha Scott Hersha is offline
I have a similar setup on my RV6 build. It’s made out of aluminum bar stock. The original rudder stop from the kit builder I bought it from made two of these (top pic below), so I decided to use both of them, one on the top of the rudder bottom clevis mount and one on the top. I needed a spacer between the clevis mounts to not put too much squeeze on the bottom rudder rod bearing so I couldn’t insert it.
Click image for larger version
When I did this I had to file the two pieces to make them match exactly, and that resulted in a max rudder deflection of 35* (the upper limit), and too close to the limit for my comfort, so I made a new one out of 1/8” stock. I still bolted it to the bottom rudder rod end clevis using a spacer to prevent squeezing the clevis too much, but it works very well. My max deflection is now 32.5*, which is right where I want it.
To me, I prefer the internal rudder stops, and they are easier to install and adjust.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019/sold2021
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2022
Old 01-20-2022, 03:23 PM
Joe Joe is offline
I don't see a copyright notice on it so here's a PDF of the design Rene Bubbeman did 17 years ago.
If you email me (jdubner@yahoo.com) your email address I will send you a DXF and/or a DWG file of it.
Joe
Joe Dubner
RV-8A
Independence, OR
