Go Back   VAF Forums > Model Specific > RV-9/9A
  #21
Old 11-28-2007, 12:57 PM
pmccoy's Avatar
pmccoy pmccoy is offline
Default Audio TVIO
- audio TIVO so you can play back missed messages
Tracy-
Audio TIVO... interesting idea. How are you planning to do this?
_____________
Peter McCoy
RV9A N35PM S/N:91335
First Flight: April 2013
Hobbs: 400 hours after Oshkosh 2017
www.myrv9.com
Old 11-28-2007, 01:12 PM
thallock thallock is offline
Peter,
I have a small embedded linux controller board that contains an audio codec, several MB of RAM, and several MB of flash. I should be able to interface to the RX channel from the radio, and continuously record audio to RAM, tossing out the older data on the fly. When you miss something, you could press a button and capture the last x seconds of audio and play it back.
I'm still getting up to speed on the controller board, so this is a ways off right now. Exactly where I tap into the receiver for the audio input and the audio out I do not know yet.
Tracy.
Tracy Hallock
Austin, Tx
RV-7(EH) - Fuselage
http://www.trv7.com
Old 11-28-2007, 01:19 PM
grjtucson's Avatar
grjtucson grjtucson is online now
Default Another One
I was just working on my plane and noticed my new aileron boot holders, so add that to the list:
- aileron control tube boots
BTW, I made my holders from the circular cutouts from the tank end rib construction. Perfect size!
George
George Jenson - http://www.georgejenson.com
Tucson, AZ - N567AJ RV-7 Standard Build
Empennage 1/06, Wings 11/06, Fuselage 9/08, Panel Wiring 7/19, to airport 10/20, first engine run 2/21. AWC 11/11/21. First flights 11/17/21. My first flight 12/17/21, my first solo 12/20/21.
Monthly donor, I appear on the list as Jenson Consulting
Old 11-29-2007, 07:16 AM
AllanC AllanC is offline
One more I don't see, but consider essential in my -9A is a sliding sunshade - the one that fixes to the center rail above your head - also fixes to the tip-up canopies as well. In addition, i think I will also install one of the forward tip up canopy devices to me slider - getting bulky items in the rear is a pain, and additional access would be helpful.
Allan
Old 12-07-2007, 04:42 PM
Bill Ervin Bill Ervin is offline
Default extra fuel
I know of an RV10 that has two full sets of fuel tanks in each wing. One inboard and one outboard with a little bit of space in between. I was thinking of doing the same thing only using half a tank on the outboards. I was also thinking of using andair's four tank fuel valve so I could burn off tip fuel first and then the mains similar to the Cherokee 235.
To solve the "how to run the fuel line problem" I figure on running the outboard line through the inboard tank. I might find out I'm all wet here, but it looks good on paper!!!
Bill Ervin
RV-9A Emp
Eagles Nest Estates
Midlothian TX
Old 12-07-2007, 05:08 PM
kentb's Avatar
kentb kentb is offline
Default Don't forget...
Originally Posted by Bill Ervin View Post
I know of an RV10 that has two full sets of fuel tanks in each wing. One inboard and one outboard with a little bit of space in between. I was thinking of doing the same thing only using half a tank on the outboards. I was also thinking of using altair's four tank fuel valve so I could burn off tip fuel first and then the mains similar to the Cherokee 235.
You will need four fuel gagues.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 12-07-2007, 08:33 PM
Greg Arehart's Avatar
Default Airstopper tubes?
Bill,
What are airstopper tubes? A modification to the vent system?
greg
Greg Arehart
RV-9B (Big tires) Tipup @KCLM or CYSQ
N 7965A
Old 12-12-2007, 08:50 PM
Kent
Actually just a GRT EFIS/MFD and one ECI duel gauge for the tips.
Bill
Bill Ervin
RV-9A Emp
Eagles Nest Estates
Midlothian TX
Old 12-13-2007, 06:15 AM
pierre smith's Avatar
Default Only two
Kent
You can get by with two gauges with a switch under each to select either tip or main. My Air Tractor has one gauge with a selector switch from the factory.
Regards,
Rv10 Sold
46 years ag pilot/CFI
Air Tractor 502/PT-6
Building RV-12, Wings, fuse, emp complete. FWF in progress.
Old 12-13-2007, 08:57 AM
Norman CYYJ Norman CYYJ is online now
If you like to baffle your flying audience with dials go with four gages. But two gages and a switch or one gage and a switch as Pierre says is the best way to go. Less weight, less cost, less to go wrong and less complications.
