Old 01-21-2022, 04:52 AM
BH1166 BH1166 is offline
Default In / Out vs Out / In
Originally Posted by Joe Jet View Post
……. The operator's manual shows the hose connections to and from the cooler and I see them backwards a lot.
Interesting comment here…I see oil hoses backwards. I was told the oil cooler lines are not designated as having an IN and OUT , can be used interchangeably. Any A&P reading that can clarify ?
Butch
RV6A Purchased N72TX
Old 01-21-2022, 08:40 AM
cajunwings cajunwings is offline
Lines or hoses should be able to flow oil in either direction. The reference may be to the oil flow entering the cooler. If 1 cooler fitting is lower than the other that is usually the IN port.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
