Go Back   VAF Forums > Main > Safety
  #11
Old 01-02-2022, 04:09 PM
Larry DeCamp Larry DeCamp is offline
Default Good input, but I will stir the pot a little.
So, for safety, van specifies large washers where they can be applied to keep the outer race from coming off the inner ball.
Yet, the kit is supplied with components that do not support the washer option, and Ralph has never seen one fail.
So, is it possible they are both acceptable, but conform to DIFFERENT material or design specs ?
Larry DeCamp
RV-4 fastback in process w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 01-02-2022, 07:40 PM
RV7 To Go's Avatar
RV7 To Go RV7 To Go is offline
Originally Posted by Toobuilder View Post
If you want to make it easier, just drill through the stud at the swage countersink and knock it free with a punch.
This is what I have done on two 4's and my 7. Very easy to do. Only takes a couple minutes to drill off the flare and drive out the stud. install with a bolt and large washer. Might need to enlarge the opening in the fuselage a bit to clear.
All of the RV's built on our field (over a dozen) have been done this way, ever since an MD-RA inspector pointed it out as potential issue years ago. Even though we have never heard of a failure of one of these ball ends we still do it just to be safe.
Al
___________
RV4 - Bought 2013 Sold 2017 after 450 hrs
RV7 - Built in 6.5 yrs & Flying 2017
RV4 - Built 2021 Time flown and Sold
RV8 - Building 2022
Old 01-02-2022, 07:53 PM
Stewbronco Stewbronco is offline
Default Or just get the correct heim joint
Very simple instead of modifying the ballpoint stud to just order the same one used on top of flap rod from VANS. On advise from a very well respected MDRA inspector that had made a " containment "arm out of aluminum I addressed this issue without molesting the heim joint . Vans designed the GREAT plane but this would be better in double shear and the rod end would need to be contained on a racecar. I don't know how to post pictures ...but Larry ..I sent you a PM
Old 01-03-2022, 08:27 AM
Toobuilder's Avatar
Fair point to order a std. heim joint in a new build, but for those with the "studded" version on hand, it takes less time to press out the stud than to open the Van's website on your computer.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
1940 Taylorcraft BL-65
1984 L39C - SOLD
RV-8 - SDS CPI - SOLD
Old 01-03-2022, 04:26 PM
Scott Hersha Scott Hersha is offline
Good points made, and easy to accomplish for me on my ďnewĒ RV6 build since Iím at that point - and I have the correct replacement bearings that just require me to grind a bigger hole in my fuse for the extra bolt end/washer assembly. But Iím still curious about the company still recommending the screw mount bearing that they do. Is there any record of failure of this joint? It seems like, with more than 11,000 units flying with this configuration, there should be some data on failures if itís a problem. Does anyone know if Vans has an opinion on this?
Iím not trying to second guess anyone, but trying to not fix something that isnít broken and possibly never has broken. Iím not an aeronautical or structures engineer, but the folks that designed my airplane are. Why are they still recommending this bearing?
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019/sold2021
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2022
Old 01-03-2022, 04:40 PM
Ralph Inkster Ralph Inkster is offline
[quote=Scott Hersha;1579
I’m not trying to second guess anyone, but trying to not fix something that isn’t broken and possibly never has broken. I’m not an aeronautical or structures engineer, but the folks that designed my airplane are. Why are they still recommending this bearing?[/QUOTE]
Well, its the holiday season, excess food & too much idle time = lets 'Overthink the engineers' on something else & create another preceived issue.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 01-03-2022, 05:30 PM
Champ's Avatar
Champ Champ is online now
Started with a std rod end, bolt & big washer then switched to Vanís design. On final inspection my MDRA rejected the Vanís design and would only approve a bolt/big washer attachment.
Dennis Enns
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, MTV-9-B/183-50a, PMags, OW Award Oshkosh 2017
2022 Donation In
Old 01-03-2022, 06:57 PM
Toobuilder's Avatar
Well, that's a bit harsh Ralph. The Op's question is valid: If the big washer is standard practice on all rod ends to contain the race within the body, and this "studded" unit is metallurgically identical to the other Heim joints that DO require the washer, why is it OK to ignore this containment practice?
And I agree - I have never seen a failed/uncontained race. I simply removed the stud in my Rocket because I changed the flap geometry and the stud would not work.
Michael Robinson
______________
1984 L39C - SOLD
Old 01-09-2022, 01:12 PM
wawrzynskivp wawrzynskivp is offline
Default To washer or not to washer
I recall paying a very experienced test pilot to go over my build prior to first flight. I learned a lot from that, but the one thing that seemed out of place was the discussion of the push rod to flap attachment on my RV7.
Unless I missed something, Van's Plans do not call out a washer on that particular Heim Joint. I assume this is due to the reliability of the joint, the need to cut the fuselage for clearance, and the problem generated by a washer hanging up on the aircraft skin.
The inspector shared his desire to see a washer there as personal and not based on any specific knowledge of failures. I can certainly see his point.
However, in that particular assembly I would point to the aluminum tube/pushrod being scored along its inner circumference during threading as being the most likely impeding failure over time. I wouldn't call it likely, or even remotely likely, just much more likely to see fatigue failure in scored aluminum rather than smooth steel.
The inspector's observation bothered me as the consequence of failure weighs heavily on peace of mind, even though the likelihood is so remote at least in my mind to be undefined. How many things can we imagine as going wrong?
I guess I am asking this question again: Does anyone know of a failure mode for these joints other than obvious overload?
Old 01-09-2022, 01:36 PM
bjdecker's Avatar
bjdecker bjdecker is offline
That's a very long list my friend. For what it's worth, the failure of that particular CM-4MS rod end bearing isn't on mine
That particular rod end is loaded in predominately in shear, a failure is likely going to happen when extending the flaps (higher loading). Back of the envelope FMEA tells me that the push rod will bend & bind before the attachment fails -- likely causing the flap motor to stop turning, blowing a fuse/circuit breaker and causing a partial or split/partial flap configuration.
...but that's just me...
Brian Decker
RV-7 (Flying)
