If you are willing to entertain the idea of changing it to a B&C alternator, that might be the last time you buy one otherwise you may be searching for best prices of a PP in the future.
Sadly, PP has had a very poor track record.
B&C is not out of the question. The pricing is very much the same. I am on the fence
Aircraft Spruce. Make sure you want the PP alt. A search here could save you some grief.
Doug, this is quite the find for genuine ND alternators in these sizes. One popped up with 60 amps too on the second link. I have looked for maybe a hundred hours for a current new ND in this configuration - and will be following up on Monday. Thanks for this vendor post!! I'll bet B&C does just that.128 bucks new, I have had this on my plane since 2015, working fine never had any issues with it, puts out a steady 14.2-14.3 volts. 1 wire. https://www.ase-supply.com/Denso_Alternator_100211_1680_p/nd-100211-1680.htm
Many certified planes are running it, field approved back when they were easy to get
Looks like that was replaced buy this one, same alternator new part number. http://www.ase-supply.com/product_p/nd-021080-0760.htm
I wonder if B&C buys them from Denso and modifies it and jacks up the price, its a fine alternator the way it comes from Denso
I installed mine in 2014 and have about 1000 hrs on the alternator. No issues at all. Just another datapoint as I am sure BC will do the same.
Ruready,yes you want the real Denso and not a knockoff. I have around 350 hours on mine, never had s problem with it. I bought another one and its still in the box, I just looked its the new part number. They are Denso from that link I posted, great quality stuff.
I bought the install kit for the L40 from B&C when I bought my Denso 40 amp, fit perfect, https://bandc.com/product/replaceme...case-mount-for-use-with-brand-x-starter/#belt
The kit was 65 bucks a few years ago when I bought it, its went up a bit. The boss mount is $85 and prewired field connector $17
Ruready; Looks like that was replaced buy this one said:http://www.ase-supply.com/product_p/nd-021080-0760.htm[/url]
Can you please provide the part/model number for your PP, or a description? Some models may be better than others. The EI60 has a bad rep.
