Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Engine Monitors
Old 09-17-2021, 12:52 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Any one get GRT EIS to play nice with Dynon or Garmin G3X
I have a GRT EIS monitor which has it's own control and display head. The display is rudimentary but the control head has serial out that works with GRT EFIS displays....
Anyone able to get the the GRT EIS (Engine Indication System) to talk to the other EFIS made by Dynon or Garmin G3x?
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2021 Dues Paid
Old 09-23-2021, 09:46 AM
skylor's Avatar
skylor skylor is offline
It's unlikely that this can be done. The GRT EIS serial data does not follow any industry standard for engine data and since Garmin and Dynon have their own engine monitoring solutions they have no incentive to support GRT.
Skylor
Old 09-23-2021, 10:32 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
But, you should be able to use the GRT probes and Fuel Flow sender with the Dynon EMS module.
Carl
Old 09-23-2021, 11:30 AM
N402RH's Avatar
N402RH N402RH is offline
If will connect and work with the Advanced Flight AF-5600 EFIS.
Rob Hickman
Advanced Flight Systems - Dynon Avionics
Old 04-21-2022, 07:54 AM
I solved the problem. I went all GRT.... like the company, people, and with airshow discount it was cheaper to buy and no charge for updates. Future upgrade and repair if ever needed will be less than the big TWO (Garmin/Dynon).
George
Raleigh, NC Area
2021 Dues Paid
Old 04-21-2022, 12:57 PM
jclark jclark is offline
Default A different take …
Skylor
“Standard for engine data” ….
Since they have been making the EIS for a long time, in SOME circles it is a/the standard. The real question, as you correctly point out is whether manufactures have enough incentive to make things work (the second part of your comments which is VERY valid).
I suspect that an innovative company could chose to use the data and somewhere there probably is such.
James E. Clark
Columbia, SC
EAA Board Member
RV6, RV8 Flying
RV6A Hoping to get back to finishing soon
APRS
Old 04-21-2022, 12:59 PM
Default You da man Rob Hickman!!
Advanced Flight Systems’ Rob Hickman just made my point.
James E. Clark
Columbia, SC
EAA Board Member
RV6, RV8 Flying
APRS
Old 04-21-2022, 01:39 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Hi George, it will be great to have you in the GRT family to get your insights and rigor in setting it up and using it to its maximum potential.
Mickey Coggins
Fresh Ukraine update from RV-6 owner Alex 16 June 2022!
http://www.rv8.ch/help-people-in-ukraine/
"Hello, world!"
