WingnutWick
Hello all,
Been trying to eliminate a vibration in the new 10 since I got it. Did the anti-splat nose bearing mod/balance, checked breakaway force, and balanced the mains. Thought this would take care of the problem but no effect. Mounted a GoPro onto the bottom of the plane for a high speed run. You can see it's the mains that begin to shudder at certain speeds. There are plenty of post about this with other models but the 10 I seem to only have found posts about the nose wheel. Any ideas why I'm getting this?
You can watch the video here, shimmy can be seen most noticeably at 00:35 when I begin to apply brakes but it occurs at taxi speeds as well with no brakes applies (will actually reduce when I apply brakes when it's happening at taxi speeds):
https://drive.google.com/file/d/17xOd6MbU6q8g5R6l5Ixb9ld9cvv5R17n/view?usp=sharing
