VAF on Twitter:
@VansAirForceNet
Old 08-09-2021, 10:30 PM
Nick119's Avatar
Nick119 Nick119 is offline
Default RV6 LED Light Conversion
Hello, All
I recently bought a RV6 and it has the original lighting and they aren't really up to my standards as I love to fly at night. Is there a good drop in LED lights to the current configuration? If so/not what does everyone recommend?
ID:	14547  Click image for larger version
ID:	14548  Click image for larger version
RV6 - N7VT
Old 08-09-2021, 11:03 PM
rcsilvmac rcsilvmac is offline
Default FlyLED
I went to FlyLED 6 pack. Incredible difference. I am NOT a builder, and used a street sign for aluminum, but fabricated my own mounting plate. A little paint and it looks fantastic. The difference in light is insane. Recently my home airport runway lights wouldn't come on, and I saw the runway perfectly.
2021, 2022 Dues paid
RV-6 with training wheel
Old 08-10-2021, 11:29 AM
KAdriver's Avatar
KAdriver KAdriver is offline
Originally Posted by Nick119 View Post
Hello, All
Is that a normal PAR 36 bulb? If so there are plenty drop in replacements. I used AeroLites. Very happy with there products. I just installed the nav/strobes and they are great so far.
https://www.aero-lites.com/
Jason
RV6
KASD
Old 08-10-2021, 10:31 PM
Frank Smidler Frank Smidler is offline
Default FlyLED Combo Landing/Taxi lights
FLYLED Combo kit was not too difficult to retrofit and they also have a nice, small wigwag module that does not require a separate switch.
https://www.flyboyaccessories.com/pr...p/705-0005.htm
Frank Smidler
N96FS, RV-6
Flying 1/11/09
1350 hr
Zionsville, IN
Formally of Stoughton, WI
Formally of Lafayette, IN
Old 08-10-2021, 10:38 PM
Paul from Flyleds's Avatar
Paul from Flyleds Paul from Flyleds is offline
Hi Nick
You likely have one light aimed high and one low at the moment, with not a lot of light coming from either!
Our Combo lights were designed with tail draggers in mind. One of the spotlights out of the four can be tilted downwards so that it is aimed properly when the tail is on the ground.
Put one of these in each wing and you'll get a heap of light for landing coming from both sides of the plane, and you can still see down both sides of the runway when you're taxiing.
Just the single taxi lights are likely to be twice as bright as what you have now. There's another three on each side aimed for landing...
There is a little more work required than just "drop in" but you will be very happy with the result. The Combos have been one of our most popular products, so I'm sure a few others will verify what I'm saying!
Paul McVitty
Flyleds.com
VAF advertiser
Old 08-11-2021, 12:34 AM
Dan 57's Avatar
Dan 57 Dan 57 is offline
Yep, replaced my old halogen light with Flyleds Combo about a year ago, can only recommend the product and Paul’s excellent service.
The unit was quite easy to install in the existing bulkhead, and just required the installation of an additional wire for the separate taxi light which I did not have before.
- ain't the Destination, but the Journey -
www.aerofun.ch
YLL On Tour... the blook:
https://vansairforce.net/community/s...d.php?t=210564
RV-6.9i #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
Old 08-12-2021, 01:33 PM
Nick119's Avatar
I am thinking about going with a seven stars on one side and a combo on the other.
Paul, is it possible to have more than one diffused light on the combo?
RV6 - N7VT
Old 08-16-2021, 11:00 AM
dmat dmat is offline
I purchased rigid flood lights for my 6A and love them. I have a set of rigid lights that I plan to put in my 6 but only need one of them. If you only have one light, and interested in a RIGID, PM me. This is the set I have but in white.
https://www.rigidlightshop.com/p-313...BoCY8YQAvD_BwE
RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
RV4: Restoration of an 80's build underway.
Donations Paid- Thank you VAF!
Old 08-17-2021, 08:18 AM
John Owen John Owen is offline
Do you have any pictures of your install and modification of the existing Duckworth bracket? I would like to have the combo but the two light version looks easier to fit in there.
Thanks.
John
