Keep VAF
Going
10-31-2021, 08:01 PM
Switching to experimental
I've been flying Certified for +10years +1000hours (Beechcraft-Sierra)
I feel It's time I switch to a more performant ship.
I never considered Experimental but I realize I was wrong.
I recently moved to the Bay Area, close to KSQL and I don't have access to a hangar.
I am looking for the shortest path to own and fly an RV but it scares me to end up with a poorly assembled kit.
Does it make sense to own an experimental plane if you don't build it yourself?
10-31-2021, 08:25 PM
It sure made sense for me, after 50 years flying certified aircraft...I'll never go back. I admire those here that build these things from scratch, but airplane kit building is definitely not for me. Be aware that you don't have to do your own maintenance, but you can do what you're comfortable with. Me...I do some of the wiring and electronics (with help), and some of the airframe but I pretty much stop at the firewall and leave it in the hands of my local AI-P.
As to vetting the build quality of your proposed EA-B purchase...you get it thoroughly evaluated by an expert. There are a number of them here and you'll find them to be well worth the expense when you get to that stage.
Experimental aviation isn't hard, it's just different. Get someone to help you.
RV-9A, 2011, bought flying
IO-320D1A (factory new), C/S
IFR equipped
AFS 5400/3500, G5, IFD440 navigator,
bunch of other stuff
10-31-2021, 09:04 PM
Like the certified world, your key is a proper pre-buy from a suitable person. The difference is that pre-buy could be done by someone other than a mechanic, like a knowledgeable builder.
Do your homework, and jump in. I did, so there's that.
Signed,
Some Guy On The Internet.
Mike C.
Sierra Nevada
RV-6A bought flying (for sale soon)
Super-8 bought flying
11-01-2021, 08:25 AM
Signed,
^^^^^^^ AGREE ^^^^^^^
Just follow this advice. I did the switch 14years ago and am SO GLAD I DID!
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2022 Donation made
www.PuertoRicoFlyer.com
11-01-2021, 09:36 AM
I second the choice for experimental aviation and the need for a thorough pre-buy by an “experienced, qualified builder/mechanic.” However, remember the airplane you eventually purchase will not be perfect! RV’s are experimental - amateur built aircraft (emphasis on amateur built).
I purchased my RV7A a little over six years ago from its original builder. My prebuy was not done by an RV expert but by a local A&P/IA. There were a lot of build quality items he missed during the prebuy that came back quickly to haunt my purchase decision that I truly questioned whether I had wasted my money.
The good news was these issues were “fixable” with only one true airworthiness issue requiring an expert to address. It took eighteen months of “fly and fix” to completely get the aircraft where I wanted it but I learned so much in the process that I wouldn’t trade the experience for anything. As a Vans technician advised me during my initial aircraft search, you can minimize build quality concerns by focusing your search on Quick Build kit aircraft but you cannot eliminate them.
My suggestion is find the RV you like, have an experienced builder AP/IA evaluate the potential aircraft, come to an agreement that seems fair to both parties and then set aside a reserve amount to cover “undiscovered prebuy issues” because there will be some.
Remember, airplanes by definition are: “ a vacuum in space that suck up your money.” However, experimental aircraft also offer the ability to expand your knowledge by allowing you to address these issues yourself that certified aircraft rules prevent you from addressing without an A&P doing the work. Besides, they’re generally much more fun to fly and have better technology than affordable certified aircraft.
The GA aircraft population is getting quite old. Most have had numerous A&P/IAs work on them with varying degrees of knowledge and quality. Lots of updates and upgrades have occurred over time that frankly make the fleet just as questionable as the experimental market. My belief is that “bang for buck” the experimental fleet offers more - it just requires a more specialized, thorough prebuy before an exchange of ownership occurs.
Jim Harris, ATP, T38, EC/KC-135A/E/R, 2008 RV7A, 2nd owner, N523RM (2015)
Superior XPIO-360 B1AA2, Hartzel CS prop, Dual GRT Horizon EX with ARINC, EIS, Garmin 340, 335 w/WAAS gps, Dual 430s (non-WAAS), TruTrak 385 A/P with auto-level & auto-trim, Tosten 6 button Military Grips, FlightBox wired to EX, Dynon D10A w/battery backup, 406 MHz ELT. Mountain High O2 system, CO2 monitor, Custom Interior, TS Flightline hoses, ETX900 Battery, Great POH!
Retired - Living the dream - going broke!
11-01-2021, 10:10 AM
I just went from certified to EAB and bought a flying RV-6A, no time free to build for the next few years, but it will happen. It's not scary once you realize that a good pre-buy is worth it's cost. If you can get a pre-buy and a once over by a local (to the purchased plane) RV'er you'll ensure a solid purchase. Like others have said, you don't need to do anything you're not comfortable with, I don't touch anything engine critical, yet, and may never do so, but I will assist an AP on engine items so I can learn and better understand my bird.
I'm more excited now about owning then I was in the certified world.
Johnny
N455DM - RV-6A - Bought Flying - 2021
Tip Up Canopy
IO-360-A2B
FP 66" Catta 3 blade Carbon
IFR - 2 Garmin G5s - 430W - GFC500
JPI EMS-350 to monitor the temps
N89WD - Flight Design CTSW - Sold 2021
Donation Happily Made!
11-01-2021, 10:37 AM
So True
Originally Posted by Tankerpilot75
The GA aircraft population is getting quite old. Most have had numerous A&P/IAs work on them with varying degrees of knowledge and quality. Lots of updates and upgrades have occurred over time that frankly make the fleet just as questionable as the experimental market. My belief is that “bang for buck” the experimental fleet offers more - it just requires a more specialized, thorough pre-buy before an exchange of ownership occurs.
Having been an Aircraft mechanic, and looking over rental aircraft just for kicks, I can attest to this fact. After 30 years of maintenance, those certified planes get to be scary to me. At least with experimental, one could update to modern technology without much trouble: rip out the old panel, and install new avionics, replace the engine for a new factory fresh, and with RVs, new parts are still available and probably will for the foreseeable future; cant say that about other kit manufacturers.
John S
Dues paid 2022, worth every penny
RV9A- Status:
98% done, 2% left to go
Structure done (less gear)
Electrical/Panel done
Firewall Forward 95% done
Fiberglass 70%
11-01-2021, 11:18 AM
DO IT!!
Just DO it!!!!!
And you will be a happier person. BUT make sure to get a good prebuy.
I bought a 6 kit in 1991 didn't get to work on it till 2001 Life and making money got in the way. Made a lot of it.
Oh ya it is still not finished. Worked on it in 2001 2002 and a bit in 2003. 1043 hours of construction.
Had a Cessna 206 to fly,
Didn't give up on the 6, BUT, I bought a finished 6A five years ago after I sold the 206.
Yes it is not perfect but I'm a mechanic and can fix anything. I still have the 6 and now own a hangar to finish it in.
I should have sold the 206 a long time ago and bought a 6A to fly.
If I was in your shoes, I'd be looking finding and getting a good RV experimental prebuy and go for it. Get ready to put some bumpers on your fun meter.
You will never go back.
Art
Fixit
11-01-2021, 12:15 PM
I feel that the experimental market is better for several reasons, including that they (especially the RV series) generally do things that the certified versions can’t get close to! Just remember that experimental aircraft aren’t supposed to be an alternative to certified, they are primarily for education and “experimentation”, although the mainstream experimental aircraft are pretty proven and cookie cutter when built to plans. I would love to see an experimental version of a Bonanza A36 with the huge baggage door, or a Cessna 185 type having speed, utility and good looks!
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
11-01-2021, 12:51 PM
The question is not so much certified vs experimental, it's what is the right plane for what you want to do. If that is to fly something with a fantastic balance of high performance, low speed handling, reasonable short-field capability and good handling on the ground in a well-proven design with thousands flying and great support and parts availability for not exorbitant cost, you can get an experimental RV, or a certified... what? Sorry I can't think of anything.
Randall Henderson
RV-6 / O-360 / CS, 1600+ hrs, 1st flight Sept. 1999
Outstanding Workmanship OSH 2000, Craftsmanship award AWO 2000
Airport committee chair & AOPA ASNV for Seaside, OR Municipal (56S), www.seasideairport.org
Last Donated January 2022
Thread Tools |
Display Modes |
