VAF on Twitter:
@VansAirForceNet
Old 09-26-2022, 04:43 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Phillips 66 oil spout
Where has this beautiful contraption been all my life? Just bought a case of Phillips 66 20w50 and the seller threw in one of these $1 oil spouts. It works great!
https://estore.hicorpinc.com/p66_ret...roduct_id=2027
Mickey Coggins
http://www.rv8.ch/help-people-in-ukraine/
Old 09-26-2022, 04:44 PM
jneves's Avatar
jneves jneves is offline
One comes in every case of Phillips 66, I love that little guy, makes the 6 quarts go by so quick. set it and forget it while you prep the next quart for fill up!!!
Johnny
N455DM - RV-6A - Bought Flying - 2021
Tip Up Canopy
IO-360-A2B
FP 66" Catta 3 blade Carbon
IFR - 2 Garmin G5s - 430W - GFC500
JPI EMS-350 to monitor the temps
N89WD - Flight Design CTSW - Sold 2021
Donation Happily Made!
Old 09-26-2022, 04:45 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Yup - they’re great when they reach! I’ve probably got more than two dozen of them sitting around (I buy a lot of oil….) - the only problem is that depending on the cowl and engine, they don’t always reach where they need to go. Always good with the cowl off though!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-26-2022, 04:51 PM
jneves's Avatar
Combine 2 of them and you will be amazed on how you can navigate the oil filler with them.
Johnny
Tip Up Canopy
IO-360-A2B
Old 09-26-2022, 04:56 PM
N49ex N49ex is offline
Per Paul's comment, they often can't be screwed in with a typical oil door with the cowl on. In my case, I fixed that by gently heating the center 80% of the curved spout and bent it straight. Now it screws right in. Just need to make sure the oil container is snapped in and balanced, so you don't need to hold onto it.
Reinhard
Old 09-26-2022, 07:10 PM
n18pf's Avatar
n18pf n18pf is offline
Default Nice funnel too
Cut the bottom off an oil bottle and attach that extension and you have a great funnel.
Paul A. Fisher
RV-7A N18PF
Q-200 N17PF
APRS track
Old 09-26-2022, 10:09 PM
Funguy's Avatar
Funguy Funguy is offline
Default Howdayadothat???
Ok, I give. How do you flip the container and spout upside down and plugged in without spoiling a drop? I'm missing something...
Cheers, Sean
RV6, Flying C-GOFG
CLA4 - Holland Landing
Toronto ON
Donated to December 2022
Old 09-27-2022, 01:47 AM
rv8ch's Avatar
Cheers, Sean
Ya gotta be quick!
I actually thought about videoing it, but I needed all my hands. The trick is to have the hole in the oil container at the top, then you can get it at a pretty good angle before any comes out, then push it vertical and snap it in at the same time.
Here's a picture with the standard funnel to hopefully clarify what I mean.
Mickey Coggins
Old 10-07-2022, 10:57 AM
cheeselion cheeselion is offline
Oh my dog, I was <today> years old when I realized that's how you're supposed to use that spout. I've been using a regular funnel and holding the bottles like a chump! My plane has a snap-in type of dipstick, so I'd kind of forgotten that the tube is usually threaded. To the hangar I go to check.
Thank goodness for VAF.
Tim E.
RV-4 2080 (bought)
BC, Canada
Old 10-07-2022, 11:14 AM
Sam Buchanan's Avatar
been here awhile
I don't snap or thread the spout into the filler neck. The spout is snapped onto the bottle and then I just hold the bottle for the ~30 seconds needed to empty it into the filler neck.
Sam Buchanan
RV-6
