Old 11-30-2021, 03:20 PM
dan carley dan carley is offline
Default Cigarette type USB port
Iím having radio interference with the USB port
Iím using for my iPad and stratus it a expensive one
Is there a good one that I can use
Thanks Danny carley
Old 11-30-2021, 03:31 PM
Northernliving Northernliving is offline
Default Try Stein
Stein has a couple that seem to work well. I believe they are modified Bluesea units.
https://www.steinair.com/product/dual-usb-panel-jack/
https://www.steinair.com/product/usb...power-charger/
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
New Superior IO-360-B1AC2 w/Hartzell Composite CS
RV8 - #83313 - Under Construction (sort of!)
Old 11-30-2021, 03:43 PM
Dan 57's Avatar
Dan 57 Dan 57 is offline
Just installed a GARMIN GSBô 15, bought from ACS, on sale 25% off at the moment. Yes, still expensive, but TSOed with short-circuit and over-temperature protection.
Gives me some peace of mind over my previous Amazon cheapie...
- ain't the Destination, but the Journey -
www.aerofun.ch
Old 11-30-2021, 06:23 PM
avrojockey's Avatar
avrojockey avrojockey is offline
I just got this to replace one that didn't have the wattage to keep up with my 11" iPad Pro on full bright. No RF interference that I can hear...
https://www.bestbuy.com/site/car-and...?skuId=6401771
The USB-C port is PD rated and delivers up to 30 watts. It will charge my MacBook or iPad Pro with ease.
Tim Holmes
Appleton, WI
RV-9A N904DC
2022 Dues Paid
Old 11-30-2021, 06:49 PM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
Thanks Danny carley
Could be the cord itself.
Jerry Esquenazi
RV-8 N84JE
Old 11-30-2021, 07:29 PM
tthrew tthrew is offline
Default Anker
I have been using Anker for a few years - no issues.
https://us.anker.com/collections/cha...avimenuFeature
Tim
RV-7A N54LH Aerosport O360 CS 1300+ Hobbs, Dynon HDX, Garmin GNC 355, GTX 330ES
Joined VAF 2015
2021 VAF dues Paid
Old 11-30-2021, 08:51 PM
cdeggz cdeggz is offline
I installed this one, no issues. Canít beat the price
YONHAN Quick Charge 3.0 Dual USB Charger Socket, Waterproof Power Outlet Fast Charge with LED Voltmeter & Wire Fuse DIY Kit for 12V/24V Car Boat Marine ATV Bus Truck and More https://www.amazon.com/dp/B07FXH5ZZK...ing=UTF8&psc=1
Dues Paid September 2021
Old 11-30-2021, 09:02 PM
N804RV's Avatar
N804RV N804RV is offline
It's gonna vary from one airplane to the next. Some folks can get away with something from Amazon. Others not so much.
If you're having problems with a non-aviation type cigarette lighter style USB charger, try this one from Sporty's:
https://www.sportys.com/flight-gear-...k-charger.html
If you want a hardwired solution that doesn't cost a couple of AMU's, try one of the BlueSeas Systems marine grade USB ports. They've tested pretty well using the TinySA spectrum analyzer as an RFI snooper. Just try to locate it a few inches away from your radio stack and/or you're headphone jacks.
https://powerwerx.com/blue-sea-1045-...QaAjB7EALw_wcB
Ken W.
Mount Vernon, WA
2022 VAF Supporter
Old 12-01-2021, 07:02 AM
WA85's Avatar
WA85 WA85 is offline
I just solved this very same issue, I had significant RF noise in my Dynon radio from my 12 VDC cigarette lighter USB charger. Installed one of these - YONHAN Quick Charge 3.0 Dual USB Charger Socket, Waterproof Power Outlet Fast Charge with LED Voltmeter & Wire Fuse DIY Kit for 12V/24V Car Boat Marine ATV Bus Truck.
It works great and no more RF noise.
Old 12-01-2021, 07:38 AM
MacCool's Avatar
MacCool MacCool is offline
Yeah, me too. I have two cigarette lighter ports and leave Ankers in them. One is on the panel and the other is on the aft pedestal. Both of them have a USB-C (with PD and 30 watts) for my iPads and a USB for other stuff. Neither one creates any interference that I can detect, either in my 430W, or the IFD440 that I replaced the 430W with.
RV-9A, 2011, bought flying
IO-320D1A (factory new), C/S
IFR equipped
AFS 5400/3500, G5, IFD440 navigator,
bunch of other stuff
