Old 10-28-2020, 07:31 AM
Desert Rat Desert Rat is offline
Originally Posted by g3xpert View Post
Terry,
While there is a static cal procedure provided in the installation manual, you should not have to perform it right out of the box. Reach out to us via email at G3Xpert@Garmin.com and we can get an exchange set up for you if you would like.
Justin
Thanks, but I'm not the original poster, just an interested bystander
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 05-17-2022, 04:23 PM
BASE1127 BASE1127 is offline
I'm having the same issue with my G5. It's off by about 90'. Is there really no way to calibrate the Kolsman window without doing a full static recalibration? Can you not just program an offset?
Eric
RV-4
Senior Parachute Rigger
Old 05-17-2022, 09:29 PM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
+1
Help us Garmin
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,700+ hrs
FFI FL-24
A&P
Old 05-17-2022, 10:55 PM
Mile High Relic Mile High Relic is offline
Default I may have a similar issue
I recently installed a pair of G5's and there is about a 60' difference between the altimeter and the G5.
I'm planning to fly tomorrow to a different airport so I'll have another datapoint.
OP, thanks for posting this.
Edit: Didn't realize this was a 2 year old thread until after I posted.
Old 05-18-2022, 06:47 AM
Walt's Avatar
Walt Walt is offline
Originally Posted by Mark Burns View Post
+1
Help us Garmin
Having done tons of alt checks and calibrations, I donít think an offset is a great idea as it offsets the entire range. Some other vendors offer that but I often end up with a full cal if I dial in an offset on the ground.
Iíve done lots of G5ís and donít recall ever seeing a large error (maybe 40í max) so Iíd be a little suspect about the reference youíre comparing it to.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Old 05-18-2022, 08:30 AM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Default Mine has been different since started flying
I have a G5X and a GDU465. Current flight hours 45.5.
Current display check.
Baro setting: Displayed Alt:
G5X 30.10 890
465 30.10 930 -- 40' difference
G5X 29.92 730
465 29.92 765 -- 35' difference
If I only had the 465 it would be perfect, I rely on the 465 which is consistent with the airfield elevation. I consider the G5 as a backup and would add 40' if I was relying on it.
Jeff Warren
Simpsonville, SC (@SC47 > 10nm NW Triple Tree)
RV14A (N14ZT), Ser#140195
FF 11/24/21; Phs 1 completed
Contribution made 12/9/21 (USArmy 2/67-2/70)
Old 05-18-2022, 02:07 PM
Originally Posted by Walt View Post
I’ve done lots of G5’s and don’t recall ever seeing a large error (maybe 40’ max) so I’d be a little suspect about the reference you’re comparing it to.
The reference might be the issue for me. I flew to an unfamiliar airport and the G5 was dead on the published airport altitude at 5150 using the local AWOS barometric reading. My altimeter and RMI uEncoder both read something different.
My home airport (KBJC) elevations range from 5566' all the way to 5673', depending on location, so I'm not even sure what the exact elevation is at my hangar.
