Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
08-11-2022, 10:42 AM
Originally Posted by dstates
But you don't need to adjust the squeeze stroke with a Numatx squeezer. The entire stroke has the same force capability vs. a pneumatic squeezer that only has full force at the end of stroke. Small washer worthy changes are not required. If you have a large difference Numatx does send you two different length rams (1/4" difference). This video is useful to see the differences in squeezers https://youtu.be/fxn5aqW7CFs.
That is true but the Numatx is out of my price range so I make due with what I have.
RV8 (N38PV): 90% completed (90% to go)
Days to Final Installation: 999
Days to AWC: 999
Days to First Flight: 999
Painting: 99% completed
Donation paid through 2022
08-11-2022, 02:12 PM
Thanks for all the responses. So if I understand it correctly, it takes a set amount of force to properly squeeze a specific diameter rivet to get the desired shop head regardless of the rivet length. You set that force by adjusting the air pressure.
I'll be on the lookout for the issues others have brought up too. Based on the generally positive responses, I've just placed the order for it and should get it next week.
Art Jackson
RV-14A Kit#140433
Last section completed: OB Leading Edges
Scrapped: Rudder
Working on: Fuel Tanks
Wing Kit Ordered 21 June 2021, Arrived May 6 2022
Construction log - mykitlog.com/ajackson
Dues paid January 2023
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" (rhymes with "booze") is the opposite of "find". "Loose" (rhymes with "juice") means "not tight".
08-11-2022, 05:23 PM
Make sure you upgrade to the lighter hose. the standard hose is way too chunky. The lightweight one is a TS Flightlines hose and is superb
https://www.youtube.com/watch?v=mcFAgD5yabk
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2022
08-11-2022, 08:37 PM
Love my Numatx
It all been said already….. but I love mine and wouldn’t trade it for anything. Probably my favorite tool.
RV-14A 140658 in progress
Zenith CH801 & 2500A amphibs - flying
Dues 2023 ✅
08-11-2022, 08:43 PM
I bought the Numatx tool with the optional hose and all the yokes before starting my -14A build. I love it and almost look forward to repetitive rivet jobs. They are expensive but you can get most of your money back when you sell it later.
Doug Rohrer
Bowling Green, KY
Flying RV-9A
Building RV-14A
08-12-2022, 07:25 AM
I have one of the originals, built by the first Numatx company. Love it. I cant speak for the newer versions, but mine is just fine. I dont use it as much any more--but its still a great tool.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
08-15-2022, 05:17 PM
Here is my setup
Doug S.
RV-14 In Process
Wing Kit Delivered 9/28/22
Tail Kit Delivered 10/31/22
Currently flying N1235D - Cessna 170A
08-24-2022, 02:43 PM
Hey guys I picked up a Numatx and have been tinkering with it. What is the length of piston travel for you guys? Out of the box there was plenty of air I had to bleed out of the lines and air leaks in a few of the air connectors, but I seem to have sorted all of that out. Piston travel doesn't seem like enough though.
Here's my setup FWIW
Ricky Brown | AVL ATC | Building RV-14A, at Empennage
Reason: added signature
08-24-2022, 10:01 PM
Piston length
The Numatx comes with two rams of different length. The longer one will squeeze most rivets, but when a longer rivet is required, the shorter ram is swapped in for the long one. This allows coverage of the range or rivets typically used. The ram is held in place by an Allen screw at the bottom of the center hole. Just unscrew that, and replace with the other ram when required for proper length.
That’s how mine came, and it covers the gamut.
Dues 2023 ✅
08-25-2022, 06:48 AM
I'll have to measure the stroke sometime, but what I've done to minimize times I need to change the ram is to buy a couple more flat sets. I've found I need the shorter ram with my dimple dies so for some short rivets I just use a longer flat set to make up the difference of the shorter ram. I think I have three lengths of flat sets right now and that has worked well.
Doug S.
RV-14 In Process
Thread Tools |
Display Modes |
