Old 09-01-2021, 01:23 PM
Tumper's Avatar
Tumper Tumper is offline
Default Insulating Fuel Injection Spider and Injector Lines
Has anyone had luck insulating the fuel injection spider and the lines from the spider to the fuel injectors? If so, what did you use to insulate it and how did you insulate it? Also, could you post some pictures.
I think I have fuel vaporizing in those lines on a hot day after landing.
Dean Eiland
Aubrey, TX
Former Vice President EAA Chapter 1246
RV-9 (yes) N369RV
Mattituck IO-360, C/S Whirl Wind Prop, GRT, Digiflight II, Garmin SL30 & GTX 330 and Hotel Whisky Aux tanks, Bla Bla Bla
Flying
Old 09-01-2021, 01:39 PM
DanH's Avatar
DanH DanH is offline
It's been discussed a lot over the years. No reported success that I recall.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-01-2021, 02:16 PM
Bicyclops Bicyclops is offline
I tried it using firesleeve and a reflective foil sleeve over that. Didn't improve the idle boiling issues and blocked some airflow to the cylinders raising CHTs. I removed most of it.
Ed Holyoke
Old 09-01-2021, 02:24 PM
bruceh's Avatar
bruceh bruceh is offline
I tried it. Used some foil covered/fiber heat tape wrapped around the lines. No real change in the low RPM on the ground with hot engine stumbling issues. Took it all off after about 9 months.
Bruce Hill
RV-9A N5771H flown over 900 hours!
APRS Tracking for KJ6YRP and Flying Over the Hills Blog
2022 VAF donator
EAA Tech Counselor, Pre Buys, Build assistance - canopy/tanks/fiberglass/electrical/repairs
Old 09-01-2021, 03:23 PM
airguy's Avatar
airguy airguy is offline
Physics is stacked against you on trying to effectively insulate these.
Garden City, TX VAF 2022 dues paid
N16GN flying 1,000 hrs and counting on 91E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Pending Repeat Offender - 10 kit is on order. TDI? Turbine? Stay tuned!
Old 09-01-2021, 03:42 PM
tgmillso tgmillso is offline
Hi Dean,
As others have indicated, this may not be the root cause of your problems. Because the mechanical fuel pump is mounted directly to the back of the engine, what may be more important is making sure the oil cooling is adequate, because the oil temp will effectively be what this pump body temp is. If the pump is too warm, as the fuel is drawn under suction to it, it may boil and mean that the pump is only drawing vapor. To help this situation, use light colours when painting your tanks to limit solar heating, insulate the fuel lines as they enter the engine compartment, put a titanium belly skin with ceramic insulation beneath the forward floor and ensure you have the best possible airflow through your oil cooler (good baffles, gaps sealed with RTV etc) or increase the cooler size if necessary (many -7 builders raise the cooler by a inch or so to improve airflow).
Tom
RV-7
Old 09-01-2021, 08:03 PM
Stewbronco Stewbronco is offline
Default Blast tube on Mechanical fuel pump
I have no evidence to support this but I think an attempt to cool mechanical pump with a blast tube ( with a shroud if possible) makes sense
Old 09-01-2021, 08:05 PM
jmra72a jmra72a is offline
Check out TS Floghtlines. They used to show custom lines for this on their website.
Bill Wilson
RV-7A
N247BW
Old 09-01-2021, 09:34 PM
Bevan Bevan is offline
I seem to recall that the shroud and blast tube for the mechanical fuel pump is recommended by Vans. I would think itís standard practice. Not perfect but it canít hurt.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 09-01-2021, 09:50 PM
Fhuber's Avatar
Fhuber Fhuber is offline
I was having problems with my IO-360 engine chugging, while idling on the ground when the engine is hot. I put fire shield on last summer and saw a big improvement with the idling. I also aggressively lean the mixture on the ground, which also helps with the idling.
F Huber
RV-7A flying
2019 Dues paid
