Trutrak and Bendix King
dvalle
I have a long story to share regarding the new Bendix King Aerocruze 100, issues and support UN-supporting they are....I'll try to get it done!
In the meantime, I have a question that I'm guessing someone on the forums will know. Will a Digiflight II and Vizion 380/385 interchange and work without any wiring or servo changes? Plug and play?
Dan
I upgraded from a ADI Pilot II to an xCruze 110. There were only a couple wires to swap on the 25-pin connector. Also added wires for the external emergency AP level button.
When I installed the ADI Pilot II (with the help of a diagram from Stein) I added ARINC wires, which were going to be a future feature. They are needed on the xCruze 110, but don't know about the 100.
My table of changed pins is attached. Ignore a few of my notes.
Dan
I upgraded a AF-Pilot (Digi II) to a Vizion. One minor wire change in the connector on the back of the AP head. A pin was reassigned to accommodate the blue button feature.
They are almost identical...
As John's diagram shows:
Pins 1 & 2 are currently your pitch servo reverse jumper. Those will become the AP level button inputs and the pitch servo direction change moves into software.
Pin 6 was power and it moves to pin 19.
