Wiring my aux audio systems into my GTR-200 (via an Approach Fast Stack wiring harness/hub), I could attach the incoming audio directly to the harness, but an old seadaddy taught me to always have a connector between a
In this case (if I have it right) the audio Hi/Lo comes out of the GTR harness. Lo goes to the ground, and Hi goes to the audio output (into the aux radio input). I could just run the Lo wire from the harness to the ground terminal strip, and solder the Hi wires together. But if I ever have to remove the system, I'd have to cut the Hi wire and resolder it when return it.
So it seems I should put at least a single connector in the Hi wire, or am I overthinking it?
TIA
TIA
