swisseagle
Hello
Yesterday at run up, the fuel pressure alarm goes on ... to high fuel pressure. Ok, no flying.
I measured 65 Ohm with no pressure (unit removed).
Compared to the oil pressure sender, there I read about 6 Ohm with no pressure. So this unit is gone!
Ground of the case, the pressure manifold and the one for the engine are fine.
Type is a 0-80 PSI, single post, VDO, made in Germany. Hooked up to a Advanced 3400s EFIS/EM
On ACS I found many oil pressure senders that would fit, but no one mention fuel pressure!?
Can I just take an oil pressure sender of the correct range and it is fine for FUEL also?
Thanks a lot!
Thanks a lot!
