Keep VAF
Going
01-30-2021, 02:53 PM
Lightspeed GM coils
Is anyone using the larger lightspeed “GM” coils? Are they the standard D555 coils from GM?
Sam
02-28-2021, 03:31 PM
LSE Plasma III coil failure
I had a coil failure of my Plasma III ignition last weekend returning from San Diego. My aircraft has 719 hours and this is the first problem with my Lightspeed ignition. I measured the resistance of the output coils and indeed the one for cylinder 3,4 lower plugs was well out of spec (7.5kOhms spec and 1.3MegaOhms measured). I called Klaus and he send 4 new coils at my request. The new coils are completely different in form and appear to be 0.5 Ohm dual output coils from Dynatek. They make high output ignition systems for motorcycles and ATVs. I needed to make new mounting brackets which was not a problem. Luckily, the existing wires fit. What I didn't expect was the positive lead on the bad coil had broken. Klaus uses coax cable and the positive lead is a solid copper wire. I'm not sure if vibration broke the solid wire and if that fried the coil. I'm not an engineer! Additional new tidbit while speaking with Klaus was the difference in spark plug gap with the new coils. Higher output and duration of the spark he says needs a larger gap at .040". My back went out today while I was working on this so I'll update when I can move.
RV-9A N435KR, Vans calendar March 2018
LIO 320 B1A, Dual LS Plasma III, AFP injection
G3x touch
Roseville, Ca
02-28-2021, 03:41 PM
A common point of failure in the LSE system is at the primary wire terminations -- ie. the Fast-On terminations AND RG-400 coax.
While risking the wrath of some and voiding the warranty, etc. etc., some of us are using good old fashioned MIL-C-27500, 2 conductor+shield 20GA wire with TE PIDG Fast-On crimps and BNC connectors for the primary connections.
Also, coils are available from Nology -- https://www.nology.com/profireauto.html, part 152 001 070 PFC-06D
Brian Decker
RV-7 (Flying)
Reason: added Nology 2nd source...
03-01-2021, 07:12 AM
Originally Posted by bjdecker
THANK YOU, THANK YOU for posting that info!!
Jason McKay
RV-10
03-01-2021, 07:21 AM
The difference in cost isn't that much and, IMHO, it's worth supporting the companies and folks who support our planes, are there even on Sunday to answer our questions and offer assistance when we need it most. I was only mentioning the equivalent product to call out the motorcycle application would seem to mean a more robust construction. Again, I'm not an engineer and only reasoning that. Take all that for what it's worth --- probably not much:-)
Best,
David
G3x touch
Roseville, Ca
03-01-2021, 10:09 AM
Best,
David
Totally agree, but it is a good idea to have a backup.
Jason McKay
RV-10
03-01-2021, 11:00 AM
Solder Sleeves
I have had luck with PIDG connectors for both the core and the shield of the RG-400. I used a solder sleeve onto the shield braid instead of the "strip it back and twist it" method. The solder sleeve has a pigtail that I then crimped the PIDG onto. The center core was backed up with heat shrink and the coax supported close to the coil. So far so good.
Kevin R. Walsh
Cozy Mk-IV
03-01-2021, 03:11 PM
That's a good idea.
Brian Decker
RV-7 (Flying)
03-01-2021, 03:20 PM
Super Moderator
I've got over 100 hours on the new, larger coils, now and they seem to be working well. Yes, the form factor is different, but making a new bracket isn't that hard. They are larger, and hopefully more robust.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES/RW
Kitplanes "Unairworthy" "Diagnostics" monthly feature
EAA Sport Aviation "Checkpoints" monthly column
Author "Pre-Buy Guide for Amateur-Built Aircraft" & "Are your Nuts Tight?"
www.Baselegaviation.com
03-02-2021, 03:18 AM
Hi Vic, which style coils are you using? For those wondering about the standard lightspeed triumph coils I believe Klaus is the cheapest so you’re best off going through him. I’m just trying to find out what the larger/heavy duty coils actually are before getting replacements and wether people have had success as there’s no real info on them. I have just heard people referring to them as GM coils.
Sam
Thread Tools |
Display Modes |
