Old 11-16-2021, 08:24 PM
MJarreau MJarreau is offline
Default Are All Pitot Tubes Equal?
We are definitely looking at heated, AOA/Pitot combination. They are available from several manufacturers. Do they interface the same way to the various avionics manfuacturers? We're not even close to looking at avionics.....
TIA!
Mike
DUES REMINDER: JAN 2023
RV-10
Tailcone: 90%
Wings: In Progress! (Bulk deburring done, most primed)
Fuse: Ordered (ETA November)
Finish: Ordered
FWF: Arrived (not yet inventoried)
Engine: Ordered (only 20 months to go!)
Prop: Ordered (ETA November)
Old 11-17-2021, 08:23 AM
dougmattson dougmattson is offline
Has anybody tried putting a rivet like a static port in the wing at a 45 degree angle for the AOA?
9A flying
Old 11-17-2021, 08:44 AM
sailvi767 sailvi767 is offline
One of the better standalone systems uses about a ⅛ inch hole drilled on the top and bottom of the wing.
RV-6 sold
F-1 Rocket
Old 11-17-2021, 09:21 AM
PhatRV PhatRV is offline
TIA!
Mike
I am using the Dynon Skyview so I installed the Dynon AOA/Pitot tube since the AOA inlet bevel angle at the tip matches to the Dynon AOA algorithm. I think the same logic applies if you choose Garmin avionics, then you would probably get the Garmin brand pitot.
RV8 (N38PV): 90% completed (90% to go)
Waiting for hangar.
Days to Final Installation: 999
Days to AWC: 999
Days to First Flight: 999
Painting: 75% completed
Donation paid through 2022
Old 11-17-2021, 04:17 PM
I have the Dynon pitot but since the AOA requires an in-flight calibration, I suspect it would work with any similar pitot However, I strongly recommend a pitot with a temperature regulated heater. Compared to an unregulated heater, you'll (1) use less power under most situations, and (2)won't burn the s... out of your hand if you touch it on the ground to "see if it's working".
Old 11-17-2021, 05:26 PM
This was discussed previously here, and it apparently works. Iím going to try it on my RV6 Iím building. My fuel tanks are off, so I can get to the inside of my wingtip and get to the inside of the pop rivet, AKA, a Vans static port. The link above shows an approximate angle for the rivet. Not critical, since you program it in your EFIS.
SH
RV6/2001 built 2000/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019/sold2021
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2022
Old 11-17-2021, 06:44 PM
gasman gasman is offline
Why would you do that, when you can just add another tube with a 45* end to your existing pitot tube??
VAF #897 Warren Moretti
2021 =VAF= Dues PAID
Old 11-18-2021, 06:38 AM
FinnFlyer FinnFlyer is offline
Drag and appearance.
Finn
N214FL RV-4 Mazda 13B Renesis First flight 20 Feb 2021
N46AZ RV-3B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
Old 11-18-2021, 07:43 AM
lr172 lr172 is offline
Yes, but not as simple as stated and definitely not 45*. Works very well on my 10 and this is now a vans option for the 12.
I put mine in the outer most bay of the wing so that I could access the backside on an assembled wing. Use 1/8" tubing and insert it into the 1/4" tubing and seal.
Larry
