Old 07-20-2022, 09:35 PM
BruceW BruceW is offline
Default Keyless chuck for Sioux air drill?
Im trying to source a compact keyless chuck for a Sioux air drill.
3/8" max bit. Most seem chunky for the sleek Sioux drill.
Looking for compact. Suggestions appreciated.
Bruce W
RV-7 QB (500+ hours)
RV-14 working the tail
Elk Grove, CA
Old 07-20-2022, 10:32 PM
Larco's Avatar
Larco Larco is offline
I have this style on my air drills one being a Sioux and it works fine. It took me a little while to get used to it on the Sioux but wouldn't change it back to a keyed chuck.
https://www.lowes.com/pd/Jacobs-Chuc...B&gclsrc=aw.ds
Larry
Old 07-21-2022, 08:33 AM
rapid_ascent rapid_ascent is offline
I have a setup like you are looking for that I purchased from Cleaveland Tools. I donít think they sell it any longer. If you do a search for Boeing Quick Change Drill you will find several places including ACS that sell the chuck. Cleaveland sold adapters for the common aircraft drill bits. They also sold an adapter which you could install a standard chuck that I use for other drill sizes. Itís a great system. The Yardstore also sells some of these pieces. In addition there are drill bits with the quick change available. It may take a little work to put this system together now but itís a great system.
Ray Tonks
2022 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
Sensenich Composite 3 Blade Propeller
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
