Old 08-28-2021, 07:40 AM
RV701775 RV701775 is offline
Default Elevator Foam Rib Question
I am about to start fabricating the foam ribs on the elevator, but the question I have is do I sand the blocks down to the black line on the paper template or to the point where the black line is completely removed?
Old 08-28-2021, 09:36 AM
JET14 JET14 is offline
Cool foam blocks
I cut them just outside of the line with a band saw and then just sanded them enough to smooth them out (just a couple of licks). Worked great!
Old 08-28-2021, 10:21 AM
squeakersc063 squeakersc063 is offline
You can always sand some off later if they're too fat when you try to install them. If they're too fat or you gunk on the b half too thick you'll see them protruding from the elevators.
Old 08-28-2021, 06:40 PM
mc607 mc607 is offline
When you weight it down while proseal sets up, donít use any foam gasket material between weighted material and skin. I put some sill gasket under mine and it really ruined my day. Left a bad ripple in the skin between foam ribs.
Old 08-29-2021, 08:58 PM
jcirelli jcirelli is offline
I'm at the same spot - I did a "rough" cut on the bandsaw yesterday, then began sanding down closer to the lines - though I still have a bit of close sanding. Ended up getting stupid hot in the hangar this weekend, and cooling off starting tomorrow, when I'll knock it out.
Old 09-01-2021, 09:38 PM
I clamped a piece of sandpaper and angle to the benchtop in order to keep the rib square while sanding. It's worked very well...
ID:	15329  Click image for larger version
