Old 06-30-2021, 01:29 AM
ppakotze ppakotze is offline
Default Cowl retaining pin alternative solution
Here is an alternative solution, we added this about 100hrs in on our RV7 as the cowl pins would also migrate during flight.
Name:	Screenshot from 2021-06-30 09-27-52.png
Old 06-30-2021, 10:33 AM
abwaldal@gmail.com abwaldal@gmail.com is offline
Default My pins can't walk
My solution on a flying plane I bought. Reason for the pop rivets. Same as the one I built.
Easy fool proof and quick.
Art
Old 06-30-2021, 06:39 PM
Steve Melton's Avatar
Default no separate retainer piece
- pins are hooked at the ends to interlock.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 06-30-2021, 07:29 PM
bullojm1's Avatar
bullojm1 bullojm1 is offline
My take on a pin retainer (pin was trimmed after pic was taken). 800+ hours and no issues. Very low profile.
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 07-04-2021, 05:14 AM
mbauer mbauer is offline
Default Nite Ize Gear Ties
My cowl pins have finger loops on the end.
Recently I made a tool to pull and push them in place. Simplifies installing them. 10-seconds max each pin. Used to take longer, best part is my arm doesn't get stuck in the opening for the oil fill anymore when installing them.
The next issue was how to secure? Original answer took about an hour to hook both finger loops. It was a fishing lure snap wire assembly.
Took forever and a day in the small confined space to hook both finger loops. Couldn't see them; had to do everything by feel. Accidently only hook one, now add time to try and get the thing un-snapped, before trying to get both again.
A month ago I found a product called Nite Ize Gear Ties. The 6" version takes 30-seconds to secure these loops.
Bend into a hook shape, insert through both loops and twist a couple of wraps and you're done. Here is a photo of some 6" long black ones, pack of six, purchased yesterday from HDepot:
Rubber coated twist ties. The rubber coating protects from arcing out any electrical issues. Can't believe how well these work.
You can order direct from Nite Ize. I bought the bright yellow ones at first, now ordering the bright orange versions. Easy to verify secure on pre-flight inspections. The black ones above won't be as easy to see.
Might even work instead of zip ties to secure loose wires/cables FWF. These bend easy but feel durable. Designed to be used over and over.
Best regards,
Mike Bauer
Mike Bauer
N999SN 1998 Syd Nelson RV-6 (purchased 2017)
UTC -09:00 Alaska
Old 08-25-2021, 06:25 AM
dfvk8n61 dfvk8n61 is offline
Default One more entry
Thanks to original builder. Works great.
ID:	15054  Click image for larger version
Name:	Cowl Pins2.jpg
Nelson
Cocoa Beach, FL
RV7A second owner
Old 08-25-2021, 05:53 PM
ArlingtonRV ArlingtonRV is offline
I can't take credit for these as I didn't make them, nor did the original builder. The guy who did the maintenance for the guy I bought it from came up with these. Really slick idea.
Steve Rush
Arlington, WA
ArlingtonRV on YouTube
RV-8 (Bought Flying)
Glasair Sportsman (Sold)
RV-8 Tail, QB Fuselage (Sold)
RV-4 (Bought Flying) (Sold)
RV-9 Tail
RV-12 120018 Flying (Sold)
RV-7 Tail, Wings, Started Fuse (Sold)
Old 08-26-2021, 06:32 AM
Avengerboss Avengerboss is offline
Default Cowl pins
Iíve been moving those internally installed pins to the outside like the RV10 cowl pins are done. So much nicer and easier to remove and install. Iíve done this on 7s and 8s.
ID:	15077  Click image for larger version
A&P, RV Prebuy inspections
Finished and flying our 10
Got me another RV8 to finish building
finished & flying 14A assist build SOLD
Building another 7 !!! Finished SOLD
another 14A assist build, Back at it again
Built: two 7s, two 8's, two 9As,10,12, assisted in 2 RV14As ,RANS S7
RV Jackpoints mfg'r "wintermotorsports.com"
When does a repeat offender stop????
Old 08-26-2021, 07:00 AM
Default upper cowl pin - self retaining
or something like this... you get the idea. compact and no extra pieces. 8 yrs operation and no issues.
or more like this. install and pull them together to lock. they naturally want to migrate together during operation so they stay locked.
heat the wire red before you bend it.
Steve Melton
Cincinnati, OH
Old 08-26-2021, 09:40 PM
jliltd jliltd is offline
That's how mine are. It works great and is easy to release by feel.
Jim Ivey
RV-8
(and a few more airplanes)
