  #51
Old 08-14-2021, 10:21 AM
Tony_T's Avatar
Tony_T Tony_T is online now
For what it's worth, the "R" should be on the Left carburetor for tractor installation. In a pusher, it would then be on the right side of the airplane. Maybe most of the early installations were pushers, or who knows why it is that way.
Picture is from Rotax-Owner videos.
Tony
E-LSA RV-12 ULS
Old 08-14-2021, 10:43 AM
todehnal todehnal is offline
Hi Tony. Well that sure adds a new wrinkle to the problem. As you know, our RV-12s have a tractor installation. If your pics is correct, then my analysis is totally wrong. I consider the left carb to be on the 2-4-side and was certain that I should have found an "L". Well, I've been wrong before. So, here I go again.....Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 08-21-2021, 07:04 AM
Well, I'm sure glad that I sent my carbs back to Lockwood. They really stepped up to the challenge. They first installed my carbs on their test engine and it ran like KRAP. Hurray, they have seen the problem!! Then they sent the carbs back through their shop and ran them on their test engine again with the same results. Additional carb teardowns, re-assemblies, and installing them back on the test engine finally proved successful. They even installed them on a flying aircraft to verify that they are indeed fixed. In their words "Smooth as glass" Best guess is that their was probably a tiny machining particle in one of the carb body port somewhere that was finally extracted through the multiple cleanings. Probably during the manufacturing process. I have since learned that this is not the first Bing carb to experience this, some of which have simply been replaced.
Yeah, I know. I have not installed and ran them on my engine yet, but I really do have confidence after getting the report. I will know for sure next week, so stay tuned.
I will not go through this again. Should I have carb issues in the future, I will make one attempt in my shop to fix it. If I still have a problem, in the trash they go, and a new set goes on; be-dammed the cost.....Tom
Old 08-21-2021, 08:45 AM
Tony_T's Avatar
Tom, thanks for the update. Good report.
Tony
E-LSA RV-12 ULS
Old 08-24-2021, 05:27 AM
I installed the throttle spring guide plates that Van designed. They really do work well and do add a bit of tension to the throttles. I was glad to see that the bulletin had good pics. It would have been very easy to install the guides backwards without them. I installed and balanced the the carbs, which went well. Ground run showed that the engine runs smooth from idle to wide open throttle and back. No more hiccups or shudders. I can safely say that whatever was causing the rich mixture, probably debris in a tiny carb body port, is fixed, thanks to Lockwood's tenacity.
The test flight showed more power on take off and climb. Probably due to not having such an over rich mixture, However I do still have high EGT on the right side. It did not go into the yellow area like before, but it is still about 125 degrees hotter than the left. Also, I have a vibration in flight that I can feel and makes me think that something on the engine is making contact with the cowling or frame. Not sure what that is, but I need to investigate. So I will keep plugging away at solutions for the rest of the issues, but the carbs certainly fixed the worst of the issues........Tom
Old 08-24-2021, 07:16 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
A couple of itemsÖ
Make sure tail of torsion spring is against the new retaining plate. Itís easy to have tail of spring misplaced Ė I did it. I donít have actual photo, so I made sketch below.
Check to see if rear valve cover on pilot side might be touching the large air duct that feeds the coolant radiator. The clearance at this location is minimal. Also, might want to check engine mount isolator bushings.
Name:	Screen Shot 2021-08-24 at 9.08.40 AM.png
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 740
Old 08-24-2021, 08:34 AM
rk2436 rk2436 is offline
My right side egt is always a touch higher than the left. That’s normal. I would recommend a dynamic prop balance now that your carb issue seems resolved.
Old 08-24-2021, 10:15 AM
I was very careful in positioning my springs and have them installed as pictured. Also, I appreciate the prop balance suggestion and plan to do that soon as well.
Old 08-24-2021, 02:43 PM
DaleB's Avatar
DaleB DaleB is offline
We just had our prop balanced a couple of weeks ago. What a different that made. Our "before" was .67 IPS, if I recall correctly. When we finished it was, as near as we cold tell, under .1, more likely around .05 or .06. It was difficult to tell exactly, because a gusting wind had come up, making readings after the last round erratic. I can tell you, it's a lot smoother and more enjoyable to fly now, for sure. And maybe we won't crack any more engine mount tubes.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 08-25-2021, 11:44 AM
So, did you have any indications that you had a cracked engine mount tube, other than the visual inspection?........Tom
