Old 06-26-2021, 05:09 PM
chevytoo chevytoo is offline
Default Cowl retaining pin
I came back from a flight and there was a large puddle of oil under the engine. I opened the oil door on the upper cowl and saw the right hand pin that holds the cowl in place sitting on the battery. It turns out the pin had shorted between the battery and the oil pressure hose. The hose has a large leak. I obtained new hose and will assemble it and install it soon. Vans drawings do not show a retainer for the pins at the firewall. I know how I will make retainers for both top cowl pins and that will be done after I clean up the oil mess. I lost only 1/2 quart but that does make a big mess. I see the advantage of modifying the cowl attach to 1/4 turn fasteners. I am confident the vertical pins on the side of the firewall will not be a problem.
Ray
Old 06-26-2021, 06:00 PM
You didnít say what model of RV you have, but cowl pins work very well on all RV models that i have seen, even on the top cowl. You just need a cowl pin retainer bracket mounted on the firewall - very easy to make/install. If you have a side by side model, it may be easier to make a small access panel in the aft surface of the top cowl in the center, to access the pins and provide the locking mechanism, but that makes it even easier to remove/install your cowl. The hinge holds the cowling very securely, doesnít pillow if done correctly, and is a fraction of the cost and weight of camlock fasteners.
Iíve used both methods, and I will be using hinges again on my current RV build.
SH
RV6/2001 built/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2021
Old 06-26-2021, 06:49 PM
I have an RV-9A. What you describe as a retainer is what I had figured to make.
Ray
Old 06-26-2021, 11:50 PM
gasman gasman is offline
I would question the installation of the "pin".
First, If a pin backed out, it would conflict with the left "pin" and would need to bend forward or down to continue to back out of the hinge.
Second, the "pin" is under tension due to the curve of the cowl and is difficult to install and remove by hand. I would say that the "pin" was not properly installed.
If your "pin" slid in and out with ease, then it was the wrong diameter. There is reason most all car manufacturers have a non metallic cover on the + terminal of the battery.
There is a reason Vans drawings do not show a retainer for the "pins" at the firewall.
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
Old 06-27-2021, 05:03 AM
BH1166 BH1166 is offline
Several months ago I inquired as to a Vans design of top pin retention…. someone shared this firewall top pin retainer. I believe this is a part in 14 kits.
Butch
RV6A Purchased N72TX
Old 06-27-2021, 07:18 AM
Walt's Avatar
Walt Walt is online now
I've seen lots of migrated pins, retainers are a good idea especially over the battery.
That situation could have been much worse. A boot on leads also helps prevent this from happening.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 06-27-2021, 01:03 PM
Thanks for the feedback. I do have boots on the battery terminals. The pin slid under the boot when it fell out. The pin is the diameter per Vans drawings and was fully installed. I like the retainer in the photo and will make one similar. Ray
Old 06-28-2021, 01:51 PM
I don't have a good picture, but I just added a couple screwes to the firewall with a spacer and washer to for a T. The handle on the pin just goes behind the T under some tension. Easy peasy.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 06-28-2021, 02:41 PM
bruceh's Avatar
bruceh bruceh is offline
Easy retainer fix. Just a small section of aluminum angle riveted to the firewall. Notched out a little slot to hold the ends of the pins.
Bruce Hill
RV-9A N5771H flown over 900 hours!
APRS Tracking for KJ6YRP and Flying Over the Hills Blog
2021 VAF donator
EAA Tech Counselor, Pre Buys, Build assistance - canopy/tanks/fiberglass/electrical/repairs
Old 06-29-2021, 01:48 PM
avrojockey's Avatar
avrojockey avrojockey is offline
Great ideas here! My pins walk but then they run into each other and stop. My battery box is in the plans location (far left side of firewall) so not sure if there's a threat of a pin short.
Tim Holmes
Appleton, WI
RV-9A N904DC
2019-2021 Dues Paid
