Old 06-25-2021, 03:29 PM
Sully73 Sully73 is offline
Default Inside Top Cowl paint
I want to paint the inside of the top cowl. What type of paint should I use?
Carl Froehlich's Avatar
A good white epoxy primer.
Carl
Old 06-25-2021, 04:16 PM
rv4ross rv4ross is offline
I used a high build primer and then a battleship grey single stage paint. Any light color should work.
Ross Scroggs
RV4. #3911
Paint and finishing stage
Old 06-25-2021, 04:40 PM
n82rb's Avatar
n82rb n82rb is offline
Ross Scroggs
RV4. #3911
why a light color?
Old 06-25-2021, 05:29 PM
Northernliving Northernliving is offline
Default Rhino Coating
Rhino 9700 works well. ACS sells it or you can buy dirrect from Rhino. It's what the composite guys use to seal their tanks.
https://coatings.rhinolinings.com/pr...oating/144/167
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 06-25-2021, 05:34 PM
bruceh's Avatar
bruceh bruceh is offline
I used West Systems Epoxy and West Systems White Tint for epoxy. The tint can be obtained at your favorite Marine Supply company. Brush or roll it on with a few coats and you'll have a nice hard candy shell that is easy to wipe down and clean. Paint can chip. This stuff is never going to chip off. It has held up great over 7 years and almost 900 hours.
Bruce Hill
RV-9A N5771H flown over 900 hours!
APRS Tracking for KJ6YRP and Flying Over the Hills Blog
2021 VAF donator
EAA Tech Counselor, Pre Buys, Build assistance - canopy/tanks/fiberglass/electrical/repairs
Old 06-26-2021, 07:41 AM
goatflieg's Avatar
goatflieg goatflieg is offline
I used Rust-Oleum VHT white engine enamel. Hope it works.
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - registered; final assembly continues; still putting out my own brush fires.
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2021... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 06-26-2021, 09:55 AM
I think a lighter color will help see any oil or fuel drops that might come up.
Ross Scroggs
Old 06-26-2021, 10:04 AM
Ross Scroggs
It also absorbs less heat than a dark color.
Carl
Old 06-28-2021, 06:39 AM
Southern Pete Southern Pete is offline
Many production aircraft use intumescent paint to help the cowling avoid falling apart in the event of a fire. Mostly water soluble and difficult to use, and need to be over coated with 2K PU/acrylic to provide any kind of hard wearing surface. Something that seals the weave and prevents oil seeping into the composite seems like the best bet, perhaps straight to 2K top coat with a good primer/undercoat?
Pete
