Old 06-13-2021, 06:56 AM
phapp phapp is offline
Default The "BIG" move -8
Hi,
Very exciting! After waaaay too many years, it's time to move to the airport, start the Vans / FAA paperwork and make initial contact with a DAR.
I'm asking for help/ideas/critique/advice for the critical move to the airport. Fuse only, no tail feathers, engine mounted.
Due to the insurance issues I've run into (they'll give me my money but potentially subrogate the transporter) for tilt-bed auto transporters / riggers with trailers in my area (insured only for cars and trucks), and the width of rental trailers for the wide gear, it's looking like a U-Haul 26' box as others have suggested is my best option. Currently in my area they all have aluminum floors.
Here's my proposed plan based on only having the side rails of the box of a 26' U-Haul to work with.
- Load tail first (home built ramps for the mains and the supplied walk board for the tail wheel).
- Tail wheel on my stand.
- Tail wheel leg secured horizontally with 2 straps, Left and right to secure aft horizontal movement. So it CANNOT swing. (Don't forget the bolts shared between the VS and tail wheel plate as Paul Dye pointed out on his move.)
- Strap over the fuse forward of the F-881B's and down to secure vertical movement.
- Chocks fore and aft of the mains
- VERY tightly wedged (big hammer, don't bow out the walls or rails!), 2x4's cross-wise fore/aft of the chocks to secure them.
- For additional fore/aft movement safety:
2 lengths of webbing through the spar carry thru. 1 directed forward and 1 aft.
- Low pressure tires
Thoughts?
2021 - 2022 Dues Paid
N423PH Schweizer 1-23 (Sold)
N83881 Champ 7AC
N446PH RV8 (reserved)
PA-25 Pawnee Glider Tow Pilot (volunteer)
CallAir A-9 Glider Tow Pilot (volunteer)
Old 06-13-2021, 07:10 AM
Kyle Boatright Kyle Boatright is online now
Most people secure the aircraft with straps around the gear legs. That allows the spring gear to flex and absorb some of the bumps in the road. Strapping to the spar or over the fuselage works against this. Also, there's no way I'd run a strap or bungee across the fuselage to hold the airplane down. If you tighten it enough to do any good, you risk bent metal.
When you say "tailwheel on my stand", I'm not sure I follow that. I'd recommend tailwheel on the floor of the truck. Secure it well. Hint: If the truck has wooden floors, a few strategically placed screws into the floor may help.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 06-13-2021, 07:48 AM
pilotkms's Avatar
pilotkms pilotkms is offline
Moved mine twice. Used a commercial tilt, flat bed both times. Like Kyle says, only held the landing gear stationary. Let the gear do its job. Itll flex for anything the truck rolls over. Mine has seen lot worse on a few of my landings.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying K
Built in SoCal KCCB, now in GA @ KPXE
750+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
Old 06-13-2021, 10:13 PM
joe_rainbolt's Avatar
joe_rainbolt joe_rainbolt is offline
I'm not implying that you are overthinking this as I am certainly guilty of underthinking the big move. I didn't think about it in any way whatsoever. I just called a tow truck and they loaded it in 5 minutes. 15 minutes later they were unloading it at the airport, safe and sound. There was no time at all to worry about it.
http://roughandreadyaerospace.blogsp...-big-move.html
My question though, is the wheelbase wider on the 8 than the 7A? My 7A had room to spare on the flat bed.
Joe Rainbolt
RV-7A slow build complete 4 July 2016
Visited all 48 contiguous states July 15-29 2017.
Blog: www.roughandreadyaerospace.blogspot.com
Old 06-13-2021, 10:38 PM
goatflieg's Avatar
goatflieg goatflieg is offline
One tiny advantage of the crankshaft debacle for me is that now I'll be transporting the fuselage with the engine off; the rebuilt engine will meet the fuselage at the hangar.
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - registered; final assembly continues; still putting out my own brush fires.
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2021... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 06-14-2021, 01:47 AM
YvesCH YvesCH is offline
We in Europe have smaller cars than in the US , thus our trailers are smaller as well... I had to make a spacer and invert my left wheel to fit it onto the trailer.. But it worked out perfectly.
I drove from the shop to the painter and from there to the airport.
My friend who is a police officer was on duty and therefore I had him drive in front of me and he stopped all other traffic so I could gently drive to the airport
ID:	12605  Click image for larger version
ID:	12606  Click image for larger version
ID:	12607  Click image for larger version
Yves - Basel, Switzerland
RV-8 #83458 HB-YUA
Donation 2020 done
Old 06-14-2021, 03:35 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Originally Posted by YvesCH View Post
We in Europe have smaller cars than in the US , thus our trailers are smaller as well... I had to make a spacer and invert my left wheel to fit it onto the trailer.. But it worked out perfectly. ...
That's a brilliant idea!
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 06-15-2021, 03:56 PM
rjtjrt rjtjrt is offline
Yves, nice stack of firewood in second photo.
Old 07-15-2021, 04:18 PM
Default Followup
It was a very good day. The fuse is tucked in and ready for final assembly in my hangar.
After weeks of phone calls and research on tow companies, box trucks and trailers I ended up finding a tow company with an aspiring aviator on staff that was willing to transport on a tilt-bed flatbed.
It went like clockwork with no issues.
Details and pics available on request for those who will follow.
N83881 Champ 7AC
Old 07-15-2021, 04:30 PM
D Weisgerber's Avatar
D Weisgerber D Weisgerber is offline
I'm glad to hear it went well for you. I moved my RV8 last Sunday. I'm going to do the Weight and Balance tomorrow.
Dave Weisgerber
RV8 N848DW. Ser#83830 done.
James Cowl
DAR inspection on 7-23-2021
First flight on 7-25-2021
Phase 2 on 9-3-2021
