Webb
Sponsor
Besides full and half stop positions, how much of opening should be used to when cracking the canopy open?
To the specific question, I have no clue as I never had the need.
My rule is canopy half open for engine start and taxi if weather permits (never start with the canopy fully open - too much chance of the canopy bouncing around in the prop wash when fully open).
Canopy fully shut for run up, The canopy stays shut until after landing roll out.
Carl
I initially had just the half stop for opening the canopy for start so I could easily reach it to close after start for the run up & mag checks just like Carl stated above. Later I decided to add another stop at about 4 “ back for taxiing around in cooler weather. It’s amazing how warm it gets even in cooler temperatures with the canopy closed. I use the forward 4” stop much more than I thought I would.
I just just added a second stop at about 4". I put it there because its hard to see the halfway stop latch over my shoulder and I can't tell when the cam is in the right position in relation to the latch. With the second one farther forward (around where my shoulder is) I can easily see when the cam is in the right spot.
I also like to put a 2 or 3 inch long rubber hose in the canopy rail at the back to keep the canopy from opening too far.. it also keeps the canopy skirt from crashing into the empennage fairing, as well as the canopy handle from crashing into the back seat bulkhead.
Tom do you have any pictures of this? I can’t visualize it
+1 Jay Pratt installed this on my -8 during the final assembly and as you say it prevents the canopy from hitting the vertical stabilizer fairing. Great tip for anyone building. Just take some appropriate diameter hard rubber tube and put it in the canopy rail channel at the very back. I forget the length of mine but I think it's a bit more than 3". Measure once the canopy is on the aircraft and determine the length needed to keep the canopy a couple of inches ahead of the stabilizer fairing.
Chris
I’ll try to get some pics but it’s hard to take a picture.. This applies to the -7 slider too.. you can take a piece of that 5/8 corrugated tube that Vans sells for the wiring or mag blast tubes.. And cut a 3 to 4 inch length and stuff it into the side slots of the canopy rails at the aft end. They act as bumper stops.
I made stops from a rubber jeweler's block I bought on Amazon (link). I cut pieces from the block to fit inside the canopy rails and cut them to a length that would allow maximum opening of the canopy but not allow the skirt to hit the empennage fairing. Three holes drilled though the blocks provide for some shock absorption for the canopy rollers.
3/4” auto hose wedges in nicely. A 2” piece on each side does the trick.
