I am currently looking at a 4 weighing in at 1020 lbs. Is that an acceptable number considering it has a O320 and wood prop?
D
D
D
Was paint, starter included in Vans empty weight?
Published empty wt for RV3 is 750 lbs. Included in the empty wt is a vacuum pump, and six pack which are all heavy. You replace it with a glass panel and it can’t possibly be more than 20-25 lbs difference in wt between the vacuum pump n 6 pack. Paint is about 15-20 lbs. What’s the difference in wt for the B wing
