To those of you lucky enough to be flying with the G3X Touch system that debuted last year, can you share with us what features you feel are needed in the system to perfect it?
I've been operating a Dynon SkyView in the past, and we had a similar thread going that Dynon would check on and then to much of our satisfaction, either provide in future releases, or disclose the challenges and reasons they could not satisfy those requests in current release plans.
I'd like to have a similar airing of grievances with the Garmin system and I feel this is a great place to do it! I will point out that so far my correspondence with Garmin (g3xpert) has been nothing but fantastic, and they've given me very detailed answers to my inquiries.
My install is commencing soon and my G600 will be removed, I've had my share of complaints with that platform but I understand their market is the certified big boys and the dollar signs come out quick.
What do YOU want to see on the future releases?
Wish List- Updated 05-25-2018
rdrcrmatt said:Zuldarin - Push frequencies to radios
http://www.vansairforce.com/community/showpost.php?p=952275&postcount=2
T.S. - G3X touch to work with G3X non-touch displays
http://www.vansairforce.com/community/showpost.php?p=952275&postcount=3
control - AP Altitude hold only mode
http://www.vansairforce.com/community/showpost.php?p=952275&postcount=4
Robert Anglin - WAAS Add-on module as to not require "big radios"
http://www.vansairforce.com/community/showpost.php?p=952275&postcount=7
cyrus - Airspace profile view
http://www.vansairforce.com/community/showpost.php?p=952275&postcount=8
digidocs - Integration with a low cost UAT transmitter
http://www.vansairforce.com/community/showpost.php?p=952275&postcount=9
Richard Connel - Multiple
http://www.vansairforce.com/community/showpost.php?p=952275&postcount=10
1. Auto option for display of trim and flap positions on the PFD.
2. Option to have the right knob still CRS when in moving map mode. (COMPLETED? per http://www.vansairforce.com/community/showpost.php?p=952832&postcount=11)
3. Tach or Hobbs time in small font inside tach on the front page. Saves having to scroll to EIS page to work out TIS.
4. Store the data files (just say 20hrs or so) onboard. That way if you forget to bring the SD card then you haven't lost the engine data forever.
5. User defined hierarchy and positioning for the EIS display elements on the PFD.
6. The EIS page needs some refinement. There's no need for most aircraft systems to split it into engine, electrical etc..just means more button (screen) pushing.
NovaBandit - http://www.vansairforce.com/community/showpost.php?p=952836&postcount=12
Richard Connel's #3, #5, #6
cyrus's Airspace profile view
Rubber-banding flight plans (COMPLETED v2.80)
Sharing XM weather data between the screens.
Pushing a flightplan created on the G3X to a GTN.
Display Virb video thru Wifi to the G3X.
Matheus - http://www.vansairforce.com/community/showpost.php?p=953276&postcount=17
Tune GNC225 from G3X Flightplan (for ILS/LOC) - COMPLETED per g3xpert
NovaBandit - more discrete inputs
marcusadolfsson - BT audio input to G3X forward to audio panel
jthocker - http://www.vansairforce.com/community/showpost.php?p=1031591&postcount=77
Input altitude at waypoints in flight plan then having VSR (vertical speed required) box for each point
GlennM - http://www.vansairforce.com/community/showpost.php?p=1039767&postcount=80
Software access to all CAN based data as selectable fields on display
maus92 - http://www.vansairforce.com/community/showpost.php?p=1040836&postcount=84
GDL-39R FIS-B data push to other displays (non-BT)
siclick33 http://www.vansairforce.com/community/showpost.php?p=1040836&postcount=87
Max flap run time setting
bkthomps - http://www.vansairforce.com/community/showpost.php?p=1040836&postcount=91
ETAD in time zone of arrival airport
jthocker - http://www.vansairforce.com/community/showpost.php?p=1040836&postcount=93
always on floor limits
maus92 - http://www.vansairforce.com/community/showpost.php?p=1040836&postcount=95
Use one screen to select pages on either display
Rick_A - http://www.vansairforce.com/community/showpost.php?p=1040836&postcount=98
Show ADS-B baro setting as data block
g3xpert reply - http://www.vansairforce.com/community/showpost.php?p=1081774&postcount=101
dweyant - http://www.vansairforce.com/community/showpost.php?p=1081769&postcount=99
oil timer / oil change interval countdown (+1 by Jimd)
stamper - http://www.vansairforce.com/community/showpost.php?p=1081774&postcount=102
W&B while flying and updating for fuel burn
Rick_A - ETED not updating when using GTN direct to
g3xpert replied - should get fixed soon
chasers03 - http://www.vansairforce.com/community/showpost.php?p=1081774&postcount=115
Change colors of displayed text
Thermos - http://www.vansairforce.com/community/showpost.php?p=1081774&postcount=119
serial data in from Emag/Pmag (+1 from dweyant, KatapaPilot, rdrcrmatt)
rjtjrt - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=125
Display Austrailian WAC, VNC, VTC charts on G3x (+1 from Tassie, dutchroll, Aussieflyer, rjtjrt)
KatanaPilot - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=128
User Profiles
AlexPeterson - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=130
Ability to give up analog MAP and RPM for more space in engine data side bar
togaflyer - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=131
Remote GTN625 that operates off the G3X
supik - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=132
G3X touch that supports FLARM
Zuldarin - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=133
2nd row of databar blocks
Robert Anglin - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=137
Prop balance sensor kit to interface with GDU (+1 from rotorbailey)
- http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=148
- InsightAvionics is doing this
bkthomps - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=144
AoA flap bias calibrations
mwardle7 - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=150
Max demonstrated crosswind component showing up with wind panel on approach to land
Walt - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=151
Altitude call out on GP/GS intercept
chasers03 - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=156
select waypoint to VNAV to when setting up VNAV
upperdeck - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=157
HUD
newtech - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=172
Airspeed callouts - V1, V2 etc.
jthocker - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=179
Taxiway labels on SafeTaxi
TShort - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=183
Vertical mounted AP Panel
Richard Connell - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=184
TRK AP panel button
mwardle7 - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=196
larger and different color barbs in winds aloft page
Timberwolf - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=197
split unit settings between G5 and G3X
mwardle7 - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=198
PIREP Form
bkthomps - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=199
make PIREPS on map more visible
mwardle7 - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=200
automatically set Wx altitude to current/nearest altitude
rdrcrmatt - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=206
Checklists as a page on main display instead of going to menu to access
Walt - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=207
Multiple VNAV waypoints
supik - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=209
discrete input to cancel master warnings / cautions
iamtheari - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=210
GMA245R discrete input for pause/resume of BT audio source
RV7forMe - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=211
Show weather via internet connection (wifi from mobile)
Ezburton - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=212
Additional discrete inputs and specific input naming
Danny King - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=215
Update to heading card sizing
mwardle7 - http://www.vansairforce.com/community/showpost.php?p=1136419&postcount=216
Wireless database updates via Garmin PIlots / Wifi built into G3x
