Fully agree, most of the water ends up at the bottom of the pan. The problem here is a bit different and can lead to corossion in certain cases. If you do a bunch of short engine runs where a lot of this water collects in the pan over time and the oil doesn't got warm enough for enough time to evaporate it out, problems occur. It does not need to boil, but the warmer it gets, the faster it evaporates out, hence the lyc oil temp recommendations. All that water at the bottom gets mixed in with the oil via the pump. It is like a blender and creates a mixture of oil and tiny water droplets. This oil / water mix then sits on the metal parts after shut down for weeks. This will allow a tiny water droplet to be held against a metal surface with no ability to evaporate (water trapped between metal and oil film), creating agressive corrosion in that spot and there are tons of those tiny droplets.
The other problem is that this water mixes with combustion byproducts and forms acids. Have seen this many times in cars that only get driven to the grocery store. Accumulations of white gunk that collects in the rocker covers and why MANY people without dehydrators do not get lifter spalling.
Very relevant to this discussion, as purging all that moisture after shut down will prevent the whole cycle. However, if every engine run gets warm enough, long enough to evaporate off all the water, you get the same result and why the majority of engines do not get lifter spalling even though they don't use dehydrators.
Some good points here. The key takeaways IMHO...
  • Mike Busch and several others have emphasized the harm that can be done by intermittent short engine runs that don't allow enough heat for enough time to evaporate whatever water has accumulated in the oil sump. It's often recommended (hotly contested) that the engine should run at operating temp for 30- 60 minutes to get rid of accumulated water.
  • The water in the oil sump, although not available for evaporation, is available for interaction with combustion byproducts to form harmful acids. IMHO, a good argument for shorter oil change intervals in an engine that may not run frequently. I change my oil and filter every 25 hours for that reason despite Lycoming's 50-hour recommendation.
  • It's also a good argument for immediate post-flight purging of the air in the engine that has a lot of moisture from the combustion and from the condensation that can occur as the engine cools. I don't think we need leaf-blower velocities or volumes but some amount of positive pressure air flow, preferably with dry air, is probably a reasonable idea.
same here, 25 hrs or about 4 months whichever comes first. Lyc recommends 4 months regardless of hours for "idle" planes. It feels wasteful to drain oil with only a few hours on it but i'd rather error on the safe side.
Interesting that Lycoming is silent about opening the oil cap and purging after the flight. May be they have no evidence that this helps at all.
And auto manufacturers are the same. 100+ years and 100's of millions of examples of engine use has shown that purging the vapor from an engine is not necessary for long term health, though there are exceptions as mentioned above. Certainly nothing wrong with it, but a whole bunch of hstorical data tells us it is not necessary. The lifter spalling problem is mostly unique to the lyc and dictates that greater attention be applied, but without an identified root cause, how do you do it. As a hint, Lyc is pretty specific about timelines for using corrosion preventative oil protection, but silent on vapor evacuation. All this would seem to imply that lyc thinks that sitting idle too long is a problem and shut down vapor is not.
I am pretty confident that if lyc thought that shut down vapor was a problem, they would dictate steps to mitigate it, just like they provide guidance on minimum oil temps to help with water evaporation from the oil. Opening the oil cap doesn't really offer much help, as there is already a 5/8 or 3/4" opening to evacuate the vapor. We have all witnessed the steam coming out of the opening and there is no reason to think the same thing is not happening at the breather tube.
Playing devils advocate, with roller lifters that come with engines like the IO360 M1B that Vans sells liter/cam wear is a thing of the past.
good point. The DLC lifters offer the same benefit and are available without case modification, so can easilly be swapped at overhaul.
... This oil / water mix then sits on the metal parts after shut down for weeks. This will allow a tiny water droplet to be held against a metal surface with no ability to evaporate (water trapped between metal and oil film), creating agressive corrosion in that spot and there are tons of those tiny droplets.
The corrosion process also needs oxygen. I think minute water droplets embedded in a film of oil can not produce corrosion, unless there is also dissolved oxygen available at the potential corrosion site?
Edit: Given that water will rust out the bottom of a steel carb float bowl or a Jerry can, I guess there must be some dissolved oxygen available. Given the thrashing the oil takes through the system, I imagine a bit of foaming and aeration is to be expected.
if the droplets are acidic they won't necessarily need oxygen to react with the metal. pure H2O - yes :)
Yes. Acid etching is an oxidation reaction but the oxidizing agent isn’t oxygen, it’s the hydrogen ions from the acid. Oxygen isn’t necessary. Classic rusting is an oxidation reaction that uses oxygen as the oxidizer.
The upshot is that water in the engine is bad, either from its direct participation in the oxidation reaction (rust), or its creation of acids which in turn can etch metal parts.
I have been a recent victim of corrosion on the cam and lifters. My engine (Eagle Extreme XIO-360 B1A2) from Redding, CA lasted 680 hours before producing metal and needing to be rebuilt. For the first 14 years the plane was in a heated and air conditioned hangar (605 hours) attached to the home. Since April of 2021 the plane has been in an insulated but unheated or air conditioned hangar with a Reiff Engine Heater with cylinder bands.
My rebuilt engine now has about 14 hours on it and is still in the unheated hangar. I'm seriously considering some type of moisture management. This problem is much more common than you think. After nearly 1 year of not flying she is flying better than ever!
Yes, i have seen it many times on cranks and cams. The pitting is microscopic, but is corrosion. Not a big deal on cylinder walls and other parts but a huge deal on lifters.
I understand oxidation requires oxygen, but not a chemist. Just assumed it is stealing oxygen molecules from other water droplets. I just know that if you pour water in a steel can, you will get corrosion on the bottom where there is no air. I just don’t understand the chemistry behind it.
Environmental controlled environments make a huge difference. You don’t get the large temp swings that create small dew point spreads (i.e. high relative humidity) or even condensation. Your experience tracks directly with my feelings on how this corrosion occurs, but still believe the engine is immune to it for a week or two after a shut down, while the oil film is there to protect the metal.
Except... Heat rises, and it can rise out of the oil filler but can't rise out of a breather tube that points down below the engine.
I am no chemist or engineer, But, at 75 and still alive, I have done and seen a thing or two. I was basically forced to work on cars, tractors and trucks by the time I was 15 years old. Been turning wrenches since.
Heat doesn't actually rise. It is the warm air that is rising, Because colder air is pushing it up. Heat in a vacuum is equal in all directions.
Water vapor on the other hand has a lot of pressure and will seek to equalize. If one opens the fill tube and leaves it open the moisture will equalize quite quickly to ambient and the problem of condensation is mostly dissipated . Until there are temperature swings to cause condensation.
""All bets"" are off if you ground run or short flight an engine and get milky oil, Because that moisture and acid is trapped in the emulsified oil.
AND milky oil costs you money.
I have an assembled 0-360 "Lycoming" engine that was open to ambient air and sat in my shop/hangar for 32 years and has never rusted cam or cylinders. I installed that engine in my RV-6A 1 1/2 years ago and it is still running 200 hours later with no metal.
I don't purge my engines, But, I do pull the dipstick and hold it up with a rag. AND I keep my plane in a fully sheet rocked insulated hangar with weather stripped doors.
Parking them outside gives you wide temperature swings and hence condensation and some lovely corrosion.
Just fly that engine and it is cheaper than an overhaul.
My luck varies FIXIT
I run a DryBot on mine 24/7. Here’s an overview from Build Fly Go…
And a follow up on its effectiveness…
moist air in the crank case needs to find its way down to the sump to be able to exit through the oil filler. I think the vapor we are seeing through oil cap is from the sump but not so much tapped air from the crank case. the oil breather may be an easier path to take for the crankcase venting .
No path needed
Diffusion is the spontaneous, net movement of particles (atoms, ions, or molecules) from an area of higher concentration to an area of lower concentration. Driven by the random thermal motion of particles (Brownian motion), this process continues until the concentration is evenly distributed. [1, 2, 3, 4]
It even does so through a semi permiable membrane, which is then called osmosis.
Same concept applies to how moist air gets into your engine without running
As long as we're already way off into the weeds, osmotically speaking, I'd toss in that although oxygen is definitely the most common oxidizing agent when we think of the oxidation process, it is far from the only one. The relevance to this conversation relates to the importance of even small amounts of water in the crankcase contributing to the formation of sulfuric acid from blowby of combustion byproducts. I'd argue that acid etching of upper engine components (cam and lifter pitting) can do more damage overall than conventional corrosion (rusting).
Too bad there isn’t any objective evidence to suggest use of a dehydrator system actually has an impact on engine longevity. All of the articles I have found are written by manufacturers of the equipment, or others, using some of the basic assumptions folks make every time this topic comes up.
It makes sense so it must work right?
Curious question For those using dehydrators, are you going to follow Lycomings SB for short term preservation if the aircraft isn’t going to be flown for longer than a month? Will you assume the dehydrator negates their recommendation?
I live in an area I can fly the one hour continuous in a month year round, use Aeroshell 15W50, designed for sitting engines, and if I know I can’t fly, like my panel upgrade, it gets preserved.
The logic behind the dehumidifier makes sense but there are so many factors that go into this topic of engine longevity, and so little actual evidence, it’s hard for me to chew. In fact, one AI search of the topic brings up VAF as an excellent resource and expert in aircraft engine dehydration. So, we speak it and it becomes reality, evidently….
I do respect those that are in the “it doesn’t hurt” camp and want to go through the process, accepting the fact that this is all based on assumption.
I think we have to take our lead from the engine manufacturer(s). They give a LOT of guidance on how to protect the engine, including steps to take during extended non use periods. I suspect that if purging case vapor was necessary to prevent engine corrosion, Lyc would provide that guidance; Not a burden to suggest removing dipstick after shut down. We can also look to the many other manufacturers of internal combustion engines and I have never seen one of them recommend dehydrator use after shut down for engine longevity. Seems pretty unlikely that they all missed this step. Many are multi billion dollar companies with extensive lab and engineering facilities.
If AI finds VAF as the authority on engine dehydrator use, that should warn us that we are quite unique in holding those opinions and apparently not shared by the majority of engine users.
No. There is no objective evidence that proves that use of a dehydrator extends TBO, or that it limits corrosion in any way. For my part, my decision to use one is based on what I consider to be pretty solid inductive reasoning, and that using a dehydrator is dirt cheap, simple to construct, really easy to use, and has no apparent downside.
It’s interesting that Lycoming recommends putting desiccant bags in the intake and exhaust ports but not the crankcase. The criteria was to operate the engine with an oil temperature above 165F to remove water and acids.
The only way to prevent this entire process is to purge the moisture out of the crankcase after shut-down with dry air.
Steve,
I appreciate your insight. Like some others, after I shut down, before I open the hangar, I pull the dipstick to get as much of the steam out (and whatever is dissolved in it) as possible. If I’m not able to fly for a couple of weeks, I put the Drybot on the engine.
Would it not result in a more complete (than simply pulling the dipstick) purge of the crankcase steam by putting the shopvac hose on the vac exhaust and forcing ambient through into the dipstick tube?
Cheers👍🏻
Remember, the manufacturer recommends engine overhaul at 2,000 hrs or 12 years and recommendations are based on that time frame. They don’t care after that 12 years how much corrosion is in engine. So why would they give us recommendations to keep engines past that point.
the container looks tiny. you want at least 3lbs of beads to extend time between baking (fills a tub like this https://www.amazon.com/dp/B004LSQVPA )
It's not hard to build your own, even I could do it 😀
I use 7.5 lbs at a time and keep an additional 7.5 lbs ready to go (I do note that silica gel beads have kind of shot up in price since 6 years ago). When the humidity in the chamber gets to 20%, I swap 'em out, take the used ones home to cook. I have to do that about 2-4 times per year...been doing it that way for almost 6 years. I use a restrictor on the pump tubing to keep a pretty low flow on the aquarium pump, just enough to be sure there is some positive pressure in the crankcase. I've tried higher air flow but I believe that high air volume from the pump is unnecessary and results in too-frequent bead changes. As I mentioned above, I periodically check the air flow by putting a condom on the output tube of my AS oil separator.
I had forgotten that I did create a PowerPoint on dehydrators for the two local EAA chapters several years ago but haven't been able to find it. Probably buried in my folder of work PowerPoints that have sitting around since I retired. I'll keep looking.
This is mine from building. I live near the coast. My tools rust just sitting in the drawers :-(
Don’t use now that I’m flying and the airport is 20nm inland.
The hygrometer measuring the engine output is in the bottle on the left.
Output on the right.
Pump is inside a pair of socks as a filter in the middle somewhere.
As a victim of cam and lifter corrosion, I would love to hear from professional engine builders (ie those that rebuild bunches of engines) what percentage of engines that "were running fine" but sent in for overhaul had cam or lifter corrosion. In other words, is this corrosion a problem for ALL or most Lycoming engines, regardless of operational considerations and we just don't see it because they weren't yet causing operation problems?
With Lycoming switching to roller tappets on new engines a number of years ago now, has anyone seen data on a before and after?
If you are pumping air in are you not adding more water?
There's literally a link to the site in the linked VAF post...
Yep it went to the post, but that post only had a picture. but that lead to the company website. I guess just an email I will try to make contact.
All other Google search attempts brought me back to the same VAF post. No response or website for a company showed up. At least for me!.
I did some weaponized research on thermodynamics using one year of per minute data from my Thermo Hygrometer which hangs inside the cowling from the oil cap whenever the plane is parked in the un-insulated T hangar. The thermal inertia of the engine (~250-280 lbs) and "breathing" of ambient air through the exhaust, intake, and the oil breather tube was taken into account.
The calculations showed that the engine was colder than the ambient air dew point for approx. 30-40 hours for the entire year. This happened only in the Spring (starting late February until May) in Mid Atlatnic when the engine was cold soaked and warm fronts came in - rainy warm spring days and cold nights. The engine sweats due to intertia and water condenses internally and on the surfaces until the engine warms up slowly to the ambient temp.
During Summer, Fall and most of the winter there were zero instances when the engine was colder than the dew point. In addition each shutdown introduced approx 1 ml of water total condensed on all surfaces (crankcase, cylinders, valves, oil sump etc) in the most conservative scenario.
based on that - running a dehydrator and flying often during Spring seems most critical, at least for my geography. Another idea was that a fresh oil change should be done during winter time to prepare for the Spring condensation events. New oil creates the lowest baseline humidity which helps the engine deal better with new condensation. All was modeled in the newest Opus 4.8, scripted, and math eyeball verified by a human with some engineering experience. YMMV :)
The temperature doesn’t need to be below the dewpoint to cause significant corrosion. This graph might not be exactly right but all the data is similar.
Does anyone have plans for how to build a desiccant dryer like has been discussed?
Post #3, but here's a bit more detail.
-Simple clear gallon plastic container. Local Jimmy John's gave me a couple.
-Amazon aquarium air pump. Big one. Moves a lot of air.
-Amazon hygrometer installed in the lid
-Amazon food strainer. Give the other two to wifey.
-Amazon dessicant beads. Two each gallon size to allow for exchange.
-AN833-4D 90 degree bulkhead
-AN818-4D Nut (2)
-AN819-4D Sleeve (2)
-AN832-4D Union
-AN924-4D Nut (2),
-1/4" soft aluminum tube.
-Rubber plug for oil filler. A friend printed an oil filler with NPT threads for another aluminum tube fitting.
-1/4" ID Tygon clear tubing
-Universal metal fuel filter (1/4" barb) to catch any airborne silica
-24 hr timer.
-Block of 2X6 to support the container so the fitting would clear. Drill or cut a notch for the fitting on the bottom of the container.
-Home Depot Homer bucket.
Drill a hole in the bottom of the container for the AN833 and install it. Flare a section of tubing and make a 90 degree bend clear of the container. Drill a big hole for the hygrometer in the lid and a smaller hole for the AN832. Install both. Flare another piece of tubing and install. Cut a section of Tygon to connect the output of the pump to the bottom fitting on the dryer. Cut another short piece to connect from the dryer top fitting to the filter. Drill the plug for a piece of tubing and insert it. Use the rest of the Tygon to connect from the filter to the rubber plug. Cut rhe handle off the 4" strainer and place it on the bottom of the dryer over the fitting. The strainer sits on the bottom and keeps beads from blocking the line. Fill the dryer with beads and close the lid. Set the timer to the desired run time. Turn the timer till it starts. Air flows in the bottom and out the top. When the meter goes above 10%, I change the beads and take the others home to dry. Since it's open loop, there's no smell drying and Sweetie doesn't mind me using the oven. 250 for 3 hours.
The whole rig is on a rolling tool cart along with the heater/fan, charger, sump heat power and dryer. Four circuits controlled by a Switcheon. The heater has a fan mode for post flight.
After a flight, I connect and rotate the timer till bit comes on then leave it. It will run 30 min at some point every day. The time isn't important.
-AN818-4D Nut (2)
-AN832-4D Union
-AN924-4D Nut (2),
-24 hr timer.
As I recall you have an engine from Vans purchased after 2005. If the last letter in your serial number is an “E” you have roller lifters and this thread doesn’t apply to you.
easy enough to change the model to use 60% or any other threshold instead of the dew point . i was interested in condensed water since it will have a hard time leaving the engine while it sits. the vapor has a chance to escape as long as it stays as vapor :)
I have no idea what the right answer is. Like you I assumed the absolute humidity was the driving factor. More water more rust. The thing is the “critical humidity” often quoted as 40% is for rust which is water+oxygen+iron to ferrous oxide. The other reactions with nitrogen,sulfur or chlorine are different. Couple that with the case of sliding friction of a cam/lifter surface where a microscopic nucleation site scrapes a groove in the other surface who knows.
I’m pretty sure someone who is parked 5 miles from the ocean and is continuously pumping dry air into the engine is doing the wrong thing
good points. modeling corrosion is a big can of worms and all above my pay grade. We cannot use a fixed humidity threshold because corrosion rate is also temperature and PH dependent, and acids composition, how much oil and corrosion inhibitor is on the metal surfaces etc etc. My simple brain just wanted to understand why lycoming wants oil changed every 4 months on a sitting plane - it looks like this is because the engine breathes in water after cold soaks, it settles and sometimes even turns into acid, and lycoming believes it's not a good thing.
Yes. Nice someone keeps track. Yes. I have a roller. I don't see how a dryer could harm my roller tappet engine though.
Someone asked how to build one. No specific person addressed. I answered. I will recuse myself.
