DeltaRomeo
doug reeves: unfluencer
Staff member
RV News That Caught My Eye Over The Last Day or So ….dr
__________________________
RV12 Rotax 912ULS Engine Vibration…cactus man reply
There is also 4 aluminum engine mount bushings that you probably already have....if you are gonna do the work i always say might as well order all the hardware nice and fresh...YMMV....there was a S/B for soft isolators a long time ago... but as others have mentioned - make sure your blades are properly angled...carb balance....dynamic prop balance...gear box - maybe gear box....you can rent a puller and send that off for rebuild....
Stein Air Shirts Lead the Way from Texas to Tennessee…Tanya
Oil pressure question
Rebuilding a Cowl Edge …CTCole
Got to be frustrating, but the cowling edge can be rebuilt. When completed the repair is as strong & invisible as the original. I cut one of the upper sides too much, had to build back about 1/8". The trick was to include fiberglass cloth on the inside, and clamp a flat form (with wax paper) on the outer, finish side, then trim back to the desired dimension. Some photos attached.
https://vansairforce.net/threads/cowling.228669/post-1783194
Rear handle on slider canopy …David Lewis setup
I made small left and right finger lifts out of 3/4" angle, as well as a small center lift out of 'H' shaped aluminum. Shaped how I like them. Works great for me.
Screenshot 2024-07-31 at 5.19.08 PM.pngScreenshot 2024-07-31 at 5.19.16 PM.png
OSH’24 Field Reports (PIREPs / News / Pics / Recipes)
WDYDWYRTW? (7/27-28/2024)
https://www.vansairforce.net/threads/wdydwyrtw-7-25-26-2024.228571/
OFF TOPIC:
PS: Older issues of the ‘VAF News’ can be found at:
