DeltaRomeo
doug reeves: unfluencer
Staff member
Apologies for not having a VAF News edition on the 15th. One of my other jobs took up the whole day and night. ;^)
Hope you have a wonderful Wednesday.
v/r,dr
RossK Build Update
One bite at a time..... Wing skins match drilled and leading edge rivetted on
RE: RV-8 Stick Wiring …Mike W
I used some 3/8” aluminum tube as conduit over to an in-line D-sub under the mid-cabin cover
David Paule 3B Update
While I was working on the never-ending hose chapter of this saga, I spent a few minutes trimming the #3 aft baffle to provide more clearance for the manifold pressure sense line.
Classified Spotlight
g zero
What is the MS or NAS number for this type of AN Drilled Bolt ? A supplier that carries them? Would make safety wiring things like brake calipers a little easier/ cleaner
dr
kens_cockpit
OFF TOPIC:
