DeltaRomeo
doug reeves: unfluencer
Staff member
Hope you had a nice weekend and enjoy today's edition - so much RV info I split it into two posts. Hot damn it felt nice to take the RV-6 for a local spin on Saturday morning. Dang enjoyable. I’ve got a pretty clobbered week/weekend coming up, so I might be in and out of comms. Apologies.
Have a great Monday.
v/r,dr
dr
Daddyman58
RE: RV-14 Taildragger Wing Install Tips
…jetmart reply
You may want to tie the the tail down when in the two point position. Tail is very light with the wings off.
mulde35d
FuturPilot
Fugitive
The VAF News - 3.3.2025. #6288. 2/2
kirkbauer
DanH
moespeeeds
Dan 57 RE Elevator Trim
Sunday morning, quietly enjoying the digestive process of the excellent brunch we just had, installed in my favorite armchair :)
To better illustrate the debate, I picked up the pertinent illustrations from the manual and the plans... these might better explain the potential problems from altering the HS AoI on its own.
Are 'Always On' Avionics a bad idea (Smoke in the Cockpit)
…TASEsq reply.
I took a closer look at z-14 and removed from the diagram all except the main structural parts.
My system, as it turns out, is 95% functionally similar to z-14. If you imagine that the z14 “aux bus” = my “main bus” and the z-14 “main bus” = my “engine bus” then there are only a couple of differences:
- mine is designed to have the x-tie closed at all times, with the monkworkz in backup mode.
- I added a diode isolated feed from the main bus side to the engine bus side.
- I drew in where the “essential bus” fits.
O-320 FAB Question
…RussellT reply
For better or worse here is how I did mine. Covered the gaps with some baffle material and a flexible silicone flap seal. Platenuts to make the whole thing removable.
rockyfatcat
OFF TOPIC:
