DeltaRomeo
doug reeves: unfluencer
Staff member
Out at 52F for a bit Wed, and parked on my taxiway to work the iPad and answer an email or three. Saw this 185 taxiing out and decided to get the iPhone over near a sign for a pic. Turned out pretty good.
Spring has arrived in N.TX (and the pollen).
Wishing you and yours a happy, safe and RV-filled weekend.
v/r,dr
Wing Day …Rob Reece -8 52F
Many years in the making. Super happy for my buddy Rob. dr
A “Gotcha” on the ailerons….Page 34-10, attachment of the A-15008-1 stainless tubes. They are not end for end symmetrical. There is an inboard end and an outboard end. If attached flipped, the six leading edge holes won’t quite line up with the skin, but they are close enough that a person might put a lot of time and effort into trying to make it fit.
Another note is that the nose ribs require serious fluting into order to bring holes into alignment with skin. I needed two deep flutes on the top two tabs for alignment.
Here's the hardware I've been working with.
It's got a Pi Pico 2 W (RP2350) microcontroller, ADXL345 accelerometer, DS3231 real time clock, TSSP77038 IR receiver, IR333-A IR Led, and a 1 gigabyte SD card. I've almost got the firmware and app to a point where it's ready to mount to the plane and log some accelerometer data. The problem is, there's no way I'm bolting hardware like this to an airplane engine. It needs to be repackaged.
I'm sure I'll hate myself later for making this so tight and not leaving much room to run wires. But here's what my current proposed packaging looks like.
This is what happens when the internal timing slips on a mag with less than 200 hours. BTW Slick covered it under warranty and sent me a new mag
OFF TOPIC:
Past ‘VAF News’ issues:
