DeltaRomeo
doug reeves: unfluencer
Staff member
No Thursday edition due to the extra part time jobs. Doug need beauty sleep (good luck w/that). ;^). Here’s Friday’s and wishing you and yours a happy, safe and RV-filled weekend.
v/r,dr
Update: Two shops have told me the crank is not repairable. Nothing wrong with a second opinion...right?
I did find the head of the crank bolt (or at least the "bolt holding on the crank gear") in the oil sump as expected. One of the smart guys hanging around the shop noticed this is NOT an aircraft-grade bolt. It appears whomever built this engine couldn't be bothered to use the proper hardware, and raided the aircraft isle at home depot instead...which is sad. I'm surprised this bolt lasted the 100 hours or so that it did. I also discovered the castellated nut under the cam gear was never even installed.
So far, the cylinders all look good, and all the rings/pistons were intact and looked good. I have high hopes all 4 will pass inspection. All the connecting rods, however showed a bit of play or wabble on the crank...I don't think they should do that. The first look at cam and lifters look ok, but they're still in the case. I should have the case split in the next few days, then off to Tulsa with the bits for the proper examinations and testing by professionals.
I'm looking forward to an engine that I will PERSONALLY know is built right, using the right stuff.
OFF TOPIC:
