DeltaRomeo
doug reeves: unfluencer
Staff member
dr
Rest in Peace Mr. Paul Hove ….Bob Collins post
Dale Smith 7A First Flight
kirkbauer
N804RV
MacCool
RE: D-Sub Pins
…wjb
There are two commonly used d-sub pins (with matching sockets)
High-density: M39029/58-360 (orange-blue-black) for 22-28AWG
Standard: M39029/64-369 (orange-blue-white) for 20-24AWG
The they are both about 9/16" long. I used the regular density ones for the Ray Allen connections, with my crimper set "deep". You can't fit a 20AWG wire in a HD pin, but 22 and smaller works fine.
And, yes, they are small!
RE: Leak Repairs …fixnflyguy
I've done a BUNCH of leak repairs to 4,6,8 and 10 fuel tanks. Some full re-seal, some just the trouble spots. i try do do the repairs without removing any fasteners through paint, so I typically cut/install the "traditional" access holes/covers. The I/B rib can be accessed through the existing large fuel line pick up plate if installed, or the end bay baffle plate, existing or made for the repair. I have attached some miscellaneous pictures to see the process I typically use. New sealant over old (properly cured) sealant is fine, as long as it's clean and lightly abraded with Scotchbrite.
OFF TOPIC:
