N navy06 Active Member Dec 24, 2020 #1 I may end up building a RV3 fuselage tank. On the newer wing tanks what does the filler neck look like? Is it steel with a round flange that rivets to top of tank? If someone has one they could photograph, i would appreciate it. Jim
F FinnFlyer Well Known Member Dec 24, 2020 #2 Not the best picture but should give you an idea. Problem with using that in a fuselage tank would be the curvature. Van's wing tank flange is designed to fit the wing skin curvature. Not saying it couldn't be made to work. Finn Attachments FuelFlange.jpg 53.5 KB · Views: 119
n82rb Well Known Member Dec 27, 2020 #3 I believe a flat version of that flange is also available. N82rb rv-4
