Hello all,see my friend RV4 customizzed with Rotax 912 S 100 HP,CS prop GT2V14 177 SRTC hydraulic controlled and BRS system. Just 390 KG EW. https://www.facebook.com/GtProp/phot...type=3&theater
The flight scheduled in 2 weeks time.More details ASAP.
Thanks Charlie ,we do interesting machines here too.
Not only Ferrari, Lamborghine or Ducati ! ( Smile )
See RV running for the first time on yesterday.
I'll be more than happy to shear flying performance with all of you.We are all curious too .
Alex,
Great video. Like the Turbine RV4, the lighter (R912S) engine has to be mounted further forward for the CG. Both the engine, GT prop and sliding canopy appear very well engineered, not surprised given your location!
I worked very hard building my RV4 to keep the empty weight down to 925lbs (419KG) Your friend's RV4 at 390KG (859lbs) is exceptional! With the R912S the power to weight ratio should be similar to a 1000lb/150HP LYC RV4.
Now, if he upgraded to the R-914...
A lighter, more efficient engine in a much lighter weight, proven design? I look forward to the first flight report!
Ciao,
Smokey
PS:I rebuilt a Sonerai 2L "Baby RV4" in 2016 and spent alot of time at weight reduction to achieve 557lb/252KG EW. Nick Paoli (Yes, there in Italy) installed an R912S in his Sonerai S2, 40 more HP (45%) than the standard VW at nearly the same EW (252KG)!
Performance? Bellisimo!
PSS: My wife recently bought a Stelvio. A light, efficient, very well engineered 4CYL turbo Sport SUV. She likes it so much I never get to drive it!
Italian engineering!
This is going to be killer with the new 915is. The engine is heavier (about inline with a Corvair or a super light O-200). It is rated for 141hp with 135 continuous up to 15,000 ft.
