E edhunter Well Known Member Apr 28, 2023 #1 Installing governor on my IO-320, have all the parts but I'm missing a gasket between the governor drive and the accessory case. Which gasket fits here? Red arrow.... Thanks. Attachments gasket.jpg 725.2 KB · Views: 67
J jask Well Known Member Apr 28, 2023 #2 Gasket I have some gaskets. Do you have the lycoming number for the one you need?
E edhunter Well Known Member Apr 28, 2023 #3 jask said: I have some gaskets. Do you have the lycoming number for the one you need? Click to expand... I'm wondering if it's this one.... 72053. Seems like the center hole is smaller than the gear on the drive unit however... Attachments 72053.jpg 102 KB · Views: 30 s-l1600.jpg 163 KB · Views: 34
E edhunter Well Known Member Apr 28, 2023 #4 Perhaps this one? I cannot seem to find a lycoming doc that specifies which gasket.... Part #68315 Attachments 68315.jpeg 16.3 KB · Views: 27
RV8JD Well Known Member Apr 28, 2023 #5 Check out pages 2-7 and 2-8 of the Lycoming Parts Catalog: https://www.lycoming.com/sites/defa...-B%20%26%20D%20Parts%20Catalog%20PC-203-9.pdf Looks like P/N 68315 - GASKET, Accessory drive adapter (Item #4 in pic below). But check to make sure this parts catalog covers your IO-320 variant. Last edited: Apr 28, 2023
