Janaka Gamage
I'm New Here
hello Dear... can you say... how can i know ICAO address for the gtx335 s mode transponder..i installed new gtx 335 with antennas...i need to enter the ICAO address for install the set up configuration.this i am doing very first time..i am having GTX 335,gps registration code on the card.
registrar
Wherever you registered your aircraft can tell you this. I just recently did it for my transponder, but I assume I'm not in the same country as you.
They sent me a doc with the following info:
Code:
Reg.-Mark   Decimal    Binary    Octal    Hexadecimal
( I would put my values in here but I'm afraid someone will use them, and then cause an international incident. :D )
