jliltd
I have been reading VAF and talking to folks who use NGK automotive spark plugs with their PMags. From what I have learnt I gather the following:
First and foremost we should use plugs with a solid post terminal (tip), not the equivalent model number with the screw-off tip. There have been issues over time with the screw off tips loosening and arcing leading to ignition trouble. There have been workarounds like crimping hard on the tips with side cutters etc. in order to alleviate the loosening but why not avoid the whole mess by sticking to the solid tip plugs.
Next, I gather that there are 2 poplular heat ranges....
For compression ratios up to 9:1
NGK BR8ES Part Number 3961 with solid/permanent tip – standard plug
Optional Upgrade: NGK BR8EIX Part Number 6747 with solid/permanent tip – Iridium
The 8 heat range is the suggested rating in the EMag Air installation manual.
For compression ratios above 9:1
NGK BR9ES Part Number 7788 with solid/permanent tip – standard plug
Optional Upgrade: NGK BR9EIX Part Number 3089 with solid/permanent tip -- Iridium
I also hear from folks who buy the cheaper standard plugs and replace them every second oil change or so (~ 100 hrs), whereas the Iridium models can go a few hundred hours (~500). The Iridiums cost 3 or 4 times more than the standard plugs.
I would like to hear comments about my understanding of the above.
Jim
Jim
We do not recommend running past 100 hours with any automotive spark plug.
The reason is that with an EICommander installed, the pilot will notice the deterioration of the spark event once past 100 hours. This is regardless of if the standard plugs or iridium plugs are installed.
The pilot will not notice a difference unless they have a way to "read" the P-mag spark events.
Since the cost is so cheap and it is good practice to inspect the plugs once a year, we recommend replacing them during the condition inspection or at 100 hours, whichever comes first.
NGK BR8ES Part Number 3961 with solid/permanent tip ? standard plug
Optional Upgrade: NGK BR8EIX Part Number 6747 with solid/permanent tip ? Iridium
NGK BR9ES Part Number 7788 with solid/permanent tip ? standard plug
Jim
I have a 10:1 compression engine and initially went with the BR9ES heat range plugs, but suffered from numerous instances of lead bridging shorting the plug. Switched to the BR8 heat range based on their successful use in Nigel Speedy's 10:1 engine. All good now. I went with the Iridium plugs. They are rather more expensive, but still quite reasonable in the overall scheme of things.
I have a regular compression O-320 and have been running one Slick and one E-Mag (then P-mag) since around 2005. Initially I used BR8ES exclusively, but found they wore quite quickly, although it was not an issue as I changed them every annual - around 40 to 50 hours. By that time the gap would be around 0.040" or more, having started at 0.035". I also found the plugs would load up with lead to some extent.
A few years ago I switched to BR9ES after talking with NGK tech support (at an auto show) and reading their advice on the web. I have found much less wear and less lead deposits. One year I only flew 20 hours - hardly any wear. I still change the plugs each year or two ( 50 to 70 hours typically).
I do lean aggressively as soon as I throttle back after take-off & climb, and usually fly between 2000' & 4000' cruising between 140 & 150kt.
I have come to the conclusion that there are more variables than just compression ratio, and one that is difficult to quantify is operating "style". The only advice I would give is to try a higher (cooler) plug if the wear of your plugs is higher than you would like.
Pete
Pete
I agree that there are more variables, I run 1 E Mag and 1 Mag since 2001 or 2002. I think 1 other variable is if its fuel injected or carb. I think the fuel injection distributes the fuel more evenly
NGK? Not so much.
Jim
Jim,
I bought Jeff Rose's first 0-320 Electroair system for my RV4 back in 94'. Since then my HR2 and current RV6X use both a P-Mag and a EI system. In all these years NGK is my least favorite plug and the only plugs I have had fail inflight.
What are my faves?
Autolite 386 Great heat range, sold at NAPA and need no inserts.
Denso L-14U Also a great heat range and same thread as the Autolites.
Lots of years and hours on both, highly recommended.
V/R
Smokey
  • Like
Reactions: JGT
Jim,
Smokey
Smokey,
I too had the original Jeff Rose (Prior to Electroair), great ignition but eventually gave out, so I switched to PMags. I used the Autolite 386 plugs in the Jeff Rose and worked like a charm.
Am I understanding you correctly that you use the Autolite 386 with your PMags? Any issues or comparison to the NGK BR8ES? I would take the 18mm Autolite 386 any day if this is the case.
Dan
386 is great with PMAG
There are four RV's I know running Autolite 386 plugs with the PMAG including mine. All report excellent results.
Apologize if I missed it but do the Autolite 386 plugs come as a solid cap version? I did a quick search but only found them with removable caps.
Pmag Spark Plug
I've been chasing some pmag issues over the last few weeks. 1st noticed as my RPM was jumping around and then just stopped working. We cleaned all the contacts and then it appeared to be working well again, but soon started bouncing again. There was no change when doing run ups an checking mags. Last week I replaced the plugs (clearly the gaps were off) when I took the plugs to NAPA I was given a replacement plug and told it would be good, needless to say the plug was 1/2inch shorter thread, and 1" longer top (Obviously not a replacement). The original plug was NGK R 3035 BR8ECM, which is interesting now as I read the above and there is no mention of that number. I'm still trying to figure out which PMAG it really is, and how to service it. The RPM's are reading normal but jumping occasionally to a higher RPM. Any insight would be great.
Jon
Jon
I wonder what the difference between a BR8ES and a BR8CEM is? I've been running the BR8ES with good results, but I think I might try the Autolite 386 next time I do a condition inspection (January). I am also going to see about sending my E-Mag 113 in to have it converted to a P-Mag 114. I read on another post it is about $380, money well spent as far as I'm concerned.
Most important is that you get the latest firmware update to your P-mags. This is critical for continued safe operation.
I have been running 114 boards in my 113 P-mags since the 114's came out. No issues at all. Well worth the cost of the upgrade!
Did you ever find that report?
http://www.vansairforce.com/community/showpost.php?p=1348633&postcount=14
Where do you get this from, and how do you update it?
I too use 386 plugs
Started with BR9-ES but wanted to ditch the adapters so switched to 386 plugs on my pmag 200 hrs or more ago. When I added second p mag I went right to 386 plugs. They are $8 for 4 of them so when I change oil at 25 hrs I replace top or bottom plugs alternately. Usually discarded plugs are in pretty good shape with minimal lead deposits.
Auto plugs routinely go 100,000 miles. At an average speed of 40 mph so that's about 2500 hrs. And that's in both normally aspirated and forced induction motors.
Are these automotive plugs so substandard that we're not comfortable going more than 100 hrs? If that's the case why even run them? Why not stick with 80 yr old aviation plugs that will go 500 hrs or the fine wires that are good for 1000 hrs or so?
I'm finally running a LS ignition in my RV 9 and will aim somewhere around the 500 hr mark for my precious metal plugs unless of course they start talking to me. I personally believe that we have other more potential points of failure with these electronic ignitions systems that are a bigger concern.
Champion plugs in my experience were the worst for life expectancy. Autolite or Denso 👍
Tim
Tim
Last time I looked, most auto plugs where iridium or platinum and they would go that long. (100,000 miles) Switch to the old standard copper plug and then they are only good for no more than 1/4 of that time. (18,000 to 35,000-miles)
As an experiment I ran a set of Autolite 386 plugs to "failure". For this test I defined failure as anything less than perfect performance expected of new plugs. I had one plug cause an intermittent miss at 330 hours in an O-360 with 9.5:1 compression. I feel comfortable running these plugs as long as 200 hours based on this test. The fact these plugs can be replaced for less than three dollars each says 200 hours is plenty and indeed I usually just replace them at 100 hours (every other oil change).
  • Like
Reactions: JGT
I honestly didn't even realize there are 18mm auto-plug options until recently.
One has to wonder why E-mag Air recommends using 14mm plugs with adapters? Seems the 18mm plug option eliminates complexity.
The options for 18mm plugs are very limited, and they don't seem to be quite as good as the 14mm plugs. The main application for the 18mm seems to be very old vintage tractors and other old motors, so there is not a lot of innovation by the spark plug manufacturers with the 18mm plugs. The 14mm-18mm adapters are not much trouble if you buy good ones and take care when torquing them.
