sansoneservices
Worn out subject and I have read the posts regarding the issue.
Yesterday I was in 75% cruise power, peak egt to set mixture, cylinder temps were all around 320°, rpm 2350 and I detected a slight miss with a faint rumble sound (4hr flight). Landed to uncowl/inspect. Pulled top plugs and did a "thumb" compression test. Found nothing wrong, performed high power run-up, took off. Today I used the valve wizard and went straight to the #2 jug.
Ex valve sticking (again) 😳 last year I used a 1/2" ball hone and I'm thinking it wasn't aggressive enough. Apologies for starting another sticky valve thread
well, enough experience here with freeing valves from C90s to O-320/360s and 390s, and though all due respect to gone Bob with whom I argued several times about it, wouldn't use a ball hone for this job... so, at the risk of repeating myself, I've always used an adjustable reamer for the job, with excellent and repeatable results.
The advantage is logical and obvious, to me at least, in that if properly adjusted, only the coke deposit on the combustion chamber will be removed iso of honing the whole length of the guide which usually, again usually, doesn't need it.
Your case is a bit off though, as most of those happen with warning signs whilst starting the engine from cold, and seldom happen once in flight. Yes, also those happen as I experienced myself once following a long descent from altitude...
One tip if using leaded fuel, be sure to check the valve stem thru the lower spark plug hole for lead deposits, and also clean it before reinstalling the valve into the guide.
Thanks for sharing.
The ball hone could work just fine. However how it is used, and how much deposits vs guide material is removed, could end up being highly variable. Really the only way to tell would be some of pin gauge or inside micrometer.
I don't think it would hurt to repeat with a reamer and dress with a hone after that.
Could you post your CSV of the last 2 engine starts? I have a theory on how to detect these early on. If you post, you'll need to zip the files. Thanks
The ball hone does take a bit of time to do its job. Possibly you went too quick. Next time be sure that you don’t stop honing while the guide ID is still black. You should be seeing bronze or shiny metal before stopping. It is not aggressive like reaming. Going a bit too far won’t take off any material.
which, if the reamer is an adjustable one and is properly adjusted, less aggressive since it won't remove any of the guide's material, but only the carbon crud.
Applying grease on the reamer and minutely adjusting it whilst working should not attack the guide.
Done carefully this method will also warrant the concentric and cylindrical properties of the guide, which a honing ball will not.
I once worked on a heavily contaminated valve assy where the inner bore of the guide was contaminated in its middle, and the reamer helped clean this area only.
Can you elaborate on the symptoms when starting? AFAIK mine has only shown itself to be sticky while in flight, with the same symptoms as the OP. Occasional "burp" in cruise. Reamer to clean out the deposits and back to normal...
search for "morning sickness", as in the engine not immediately firing on the 4 (or 6, or 8) cylinders, coughing, maybe farting (😉), and then normalise within some seconds to a couple of minute (and only in out of the ordinary circumstances would I then go flying, the more so on a 4 banger, as loosing power on one will be hazardous to say the least).
The culprit cylinder is then diagnosed either by hand feel or EMS if so equipped.
Startup was difficult, usually 2 blades. She would try to start/run but obvious something was wrong. Symptoms like "Morning Sickness".
I was using 20w50 and had sticky valves on a new 390. I switched to 100w.
Can someone create a poll (I've looked and maybe I don't have the rights to do this) that help at least give us directional input that oil might be a factor for a sticky valve? It appears the vast majority of the incidents of sticky valves has been with users of Phil 66 20W50. I have not seen an incident of a documented sticky valve with an engine using Aeroshell 15W50. The oil chemistry is very different between the two. Just "feels" to me there is a correlation but no data. I was using Phil 66 20w50 and saw for just seconds my number 2 cyl. was slow to rise. Did a borescope and could see some black build-up around my valve guides. I switched to AS 15W-50 and stopped seeing the number 2 cyl. delay. I came close to doing a wobble test but decided to wait to see if the delay came back. Never did after over 500 hrs. IO390 engine. Most of the time it's number 2 cylinder and that is most of the time the hottest cylinder of the 4. Experts like Mike Busch "feel" a cold cylinder enhances a stuck valve which goes against the data at least for a Lycoming engine. "The truth is out there"
I fully agree, 15w50 will be in my sump next oil change. Also Phillips now has their "Victory" 20w50 and they advertise it's the greatest thing since sliced bread
Unfortunately, the forum no longer has polling capability. We could possibly use one of the polling websites (Survey Monkey, for example). However, it would mean posting a link to another website, so I think we would need Doug's blessing.
I am a firm believer that the issue is oxidized oil in the guides from too much heat. The temp at which oil becomes coke would seem to be at least somewhat dependent upon the base stocks used as well as the additive package. Seems plausible that some oil blends could form coke at lower temperatures than others.
In your case, I don’t think a sticking valve could make so small of an impact on egt. More likely the change made a small difference in how the rings moved in the lands, creating a slight change in compression.
