rph142
My new Titan IO-370 arrived yesterday :D:D:D. It has 9.6:1 compression ratio, dual Pmags, AFP 150 injector, cold air sump, and most importantly shiny rocker covers. Ill be mating it to a catto 3-blade prop. Props to J.B. at continental for making it an easy process!
I’m going with a 66x78 3 blade. I’ve been hyper focused on weight during the build, so I’m hoping a light airframe and high hp will offset the course pitch when it comes to climb rate.
Same engine but with Bendix mags, you're gonna love it!
I suggest you be careful with the timing on those PMAGS, high compression, advanced timing, and a hot engine will narrow the detonation margin significantly. They spec the timing at 20deg on these engines for a reason.
