Stewbronco
Hi all ...anyone have pictures of a LANDOLL balancer installed....of better yet a copy of install instructions. Many thanks. Stew
Ok thank you, I was going to pull the whole prop, extension, balancer, and flywheel as an assembly to check the crankshaft flange for corrosion per the Lycoming AD at my annual. I can remove those to remove the whole deal as an assembly to check for the corrosion then reinstall and torque to standard specs then? Thank you again
Anyone have an idea on how much a use landoll would sell for? I have one (without the aerobatic plate) that I dont need and want to price appropriately.
D
I know this thread is a few years old but do you still have the information for the company that sells them? I can't find anything online and I'm trying to figure out what type of fluid is used and exactly what hardware they use to seal it. Thanks!Yeah, I spoke with the company who makes them now and they are going for $1300! I have one that I wont be needing so I should be listing it shortly in the Marketplace.
Watching. I would like some too.I know this thread is a few years old but do you still have the information for the company that sells them? I can't find anything online and I'm trying to figure out what type of fluid is used and exactly what hardware they use to seal it. Thanks!
Silicone. Think breast implants.I know this thread is a few years old but do you still have the information for the company that sells them? I can't find anything online and I'm trying to figure out what type of fluid is used and exactly what hardware they use to seal it. Thanks!
Send me a message please, I would love to know more. Was there only one size made? What’s the price?Here is the silicone fluid I used. I sent a sample to Midwest Lubricants from my balancer. They tested and matched it to this.
I have a Landoll balancer I would sell. PM me if interested. They do make a difference.
Thanks for the info! Did you use any sealant around the edges to keep it from leaking or are the tolerances enough to keep the fluid inside?Here is the silicone fluid I used. I sent a sample to Midwest Lubricants from my balancer. They tested and matched it to this.
Only a film of red silicone on the mating surfaces.Thanks for the info! Did you use any sealant around the edges to keep it from leaking or are the tolerances enough to keep the fluid inside?
Sending you a PMI have two extra brand new balancers for sale ...PM for details
I'd say perfectly so!Is this cat installed in this inertia ring box properly?
