airguy
Unrepentant fanboy
Sponsor
Just FYI for the group.
I'm getting closer to pulling the trigger (not quite there yet) on a Rocket build, and thought I'd check the insurance market. Gallagher came back as a "no-quote" on all underwriters due to make/model - no new coverage is available for Rockets in the current tight market.
Talk to Ladd Gardner. He owns a Rocket and knows the companies that will insure them. 1 (972) 250-0400
I went with Assured thru AOPA. Was the best rate offered when I was shopping around last spring.
I’ve been working my insurance through Scott ‘Sky’ Smith for years. USAIG is the only company I’ve been able to get a quote from for hull & liability. Scott gives me the responses (or lack there of) from each company he goes to. My renewal is coming up in December. I’ll have to see how it goes.
https://skysmith.com/
To the OP: try Avemco. They don’t use brokers, so Gallagher didn’t get a quote from them. Be sitting down, it seems like Avemco will quote nearly anything, but at a very high premium. For sure, try another broker/agency. But if they find something Gallagher didn’t, I’d want to know why. That’s not how the system is supposed to work.
I was with A.I.R. last year. 16000tt, 500tw, 400tw in rv aircraft and 10tt in the rocket. They quoted $5800/yr for full coverage on $135k hull value. I went with straight liability for $1925/year. My policy was up for renewal in October. I went with avemco this year. They quoted $1950/yr for hull/ground motion/liability. This would cover anything up to entering and exiting the runway. I went with straight liability for $500/year.
Rockets are expensive to insure if you need or want hull/in motion coverage for a loan. Liability alone is cheaper than my tri-pacer.
I figure i will use the saved cash to feed the beast and take my chances with the hull loss if it happens. The odds are, i won’t be alive to care about the loss of value if the airframe gets totaled.
I believe Gallagher is a bit picky on the financial strength of the companies they work with (a good thing IMHO). It is possible and likely that another broker is less picky and will quote a policy from a company that Gallagher doesn't deem strong enough and therefore doesn't work with. Due diligence helps here. Most all insurance companies have a financial strength rating done by a third party.
Larry
