Rocket gear leg installation and alignment
HR2 gear typically bolts to the EM similarly to the RV-4. I don't know the bolt size required.
The F1 Rocket upper gear legs are completely different and align into a tapered socket. The F1 upper connection is NOT through bolted.
The axle end is a through bolt connection. I recall it being a 5/16" bolt (AN5-XX)
We recommend alignment be done with flying weight on the plane. We use 1600#. That usually means adding sandbags to get the plane to the right weight, filling the tanks, etc. as needed.
- Tailwheel on the ground.
- Main wheels on greased plates.
- Wheel pants off.
- Clamp a 6' straight edge to each brake disc and level it parallel to the floor. (angle aluminum or similar works well)
- Drop a plump bob from the tip of the spinner
- Snap a line (or use a string) from the tailwheel to the spinner plumb bob. (Ignore engine offset, for those who think that far ahead)
- Take some measurements to how far out of alignment the angles are from the center line.
- Set the axles to ZERO toe-in or out. Ignore the camber.
- Adjust as needed.
We make an F1 specific gear leg/axle socket clamp which makes this job safe and relatively easy. HR2 axles will require their own clamps, or it is possible to use a set screw(s) to position the axle socket. Be careful and don't make divots in the gear leg. YMMV!
You didn't ask but drilling titanium is like drilling carbon steel. Do the following:
- use new, high quality drill bits
- do not let the bit spin and harden the titanium
- slow turning speed
- keep it cutting
- plenty of pressure
- lots of oil
- drill undersize and step up to the final size incrementally.
Titanium is tough. If your bit starts spinning, and not cutting, switch to a new bit
immediately! Make certain that the new bit starts cutting immediately, oil, slow speed, plenty of pressure.... so you don't ruin a gear leg or make the problem worse.
It's easier to do this on a drill press (or mill), but it CAN be done on the plane. Taking the legs off to use a drill press means supporting the plane. Plan carefully!
