If you really meant to say wing root fairings, they are supplied with the finish kit, pre-drilled up to where they meet the fuel tanks. At least mine were. If you meant gear leg or empennage fairings, try www.fairings-etc.com. They are also starting to make fiberglass wing root fairings for the 7, i think, if you don't want to use Vans aluminum fairings. Jack N489JE
