jtrusso
Will it be legal to give primary flight instruction in an RV-12? I'm guessing that the answer is yes if the plane is certified as an ELSA, but figured I'd check with the experts here.
Thanks!
Of Course!
Even if it is certified as E-AB, the owner can receive instruction, just like any other Experimental aircraft.
You can receive instruction...but can you give instruction in a 12? Obviously you need to be a CFI and all that...but can you operate an ELSA for hire?
