Build9A
If my GPS and EZ Pilot are interlinked, can I also link my GPS to another piece of hardware, like one of the glass cockpit systems? Or can you just link one GPS unit to one other system? thanks, jack
Which GPS? What type of interface (Serial or ARINC)?
For example, if you are using a serial interface from a Garmin 430, yes, you can drive multiple outputs by using other serial output ports or my tapping the line. ARINC is a little different as you must run multiple lines from the output pin.
Tell us what GPS and think we can help you. I know Stein is on the list as well.
